+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 26
Thread: G3/8" -> G1/4" adapters for PA120.X rads?
    Xtreme Enthusiast halo112358's Avatar
    Dec 2005
    Peoples Republic of Berkeley (PRB), USA
    1
    Does anyone know where I can find some G3/8 to G1/4 BSPP adapters so I can slap 45' rotaries on my second rad? I have serious clearance issues in my current build.
    halp!
    Xtreme Mentor Eddie3dfx's Avatar
    Jun 2007
    Chicago
    0
    Sidewinders sells the bitspower ones.
    Asus P6T, I7-920, 6gb ocz xmp, 4890, Raid 0-1 Terabyte, full watercooled - Triple Loop 5 radiators
    Dec 2005
    1
    Thanks, I see them
    Xtreme Mentor Utnorris's Avatar
    Sep 2007
    Dallas
    11
    Mcmasters.com, Petrastechshop and I believe Jabtech.com all have them too.
    CPUID http://valid.canardpc.com/show_oc.php?id=484051
    http://valid.canardpc.com/show_oc.php?id=554982
    New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
    4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
    Desk Build
    FX8120 @ 4.6Ghz 24/7 / Asus Crosshair V /HD7970/ 8Gb (4x2Gb) Gskill 2133Mhz / Intel 320 160Gb OS Drive, WD 256GB Game Storage
    W/C System
    (CPU) Swiftech HD (GPU) EK HD7970 with backplate (RAM) MIPS Ram block (Rad/Pump) 3 x Thermochill 120.3 triple rads and Dual MCP355's with Heatkiller dual top and Cyberdruid Prism res / B*P/Koolance Compression Fittings and Quick Disconnects.
    Dec 2005
    1
    I couldn't find anything from mcmaster, the only G3/8 -> G1/4 fittings I saw there were NPT threaded. I also checked jab-tech & petras (PTS is local to me so they're my first source for most things) but they didn't have anything like a G3/8 to G1/4 stepdown.
    Oct 2006
    Indonesia
    0
    petra sell from mcmaster, ppcs+sidewinder from BP, go from BP they are lot cheaper.
    Jun 2008
    Northern Ohio
    0
    Want to bring this one back up. I see mention that someone had a 3/8 NPT to G1/4 fitting somewhere? I have an old MCR320 that I would love to be able to use G1/4 fittings on. Any links? I didnt see them when I just searched PTS, JabTech, PCPs, etc.
    Jun 2007
    Chicago
    0
    Quote Originally Posted by Tom128 View Post
    You can jam the 3/8 bspp adaptors in there with tape.
    Dec 2005
    1
    For what it's worth those koolance 3/8->g1/4 adapters are working great.
    core i7 920, gigabyte EX58-UD5, 4870x2
    DDC3.2 > PA120.3 > DD4870x2fc > Fuzion v1 > PA120.2 > EK Res
    I am Xtreme Waterlogged's Avatar
    Jun 2007
    Imperial Palace, UDE of Pitatopia
    0
    Click me
    It's not exact but it's more than close enough to work.
    Circles SucQ!
    Banned Snyxxx's Avatar
    Oct 2006
    Houston, Texas
    0
    You can buy this and throw the other one away.
    http://www.sidewindercomputers.com/g14adsetfore.html
    Jun 2007
    Chicago
    0
    Xtreme Enthusiast armeniandave's Avatar
    Mar 2008
    San Diego
    0
    Eddie I just went through this on my last build.
    I got the BP ones from sidewinders but they
    were a little loose so I ended up getting the ones
    from Petra's and they fit much, much better.
    http://www.petrastechshop.com/g3tog1ad.html
    i7 970 4.0 Ghz 1.325v // Asus P6X58D Premium // Windows 7 Ultimate 64bit // 12gb Corsair Dominators // 2- GTX 580 Hydrocoppers in SLI// 2-OCZ Vertex 2 Raid//128Gb Corsair SSD (Temp Storage) // Custom Wall Mount Case // Corsair 1000W // SyncMaster 2433BW // Dual loops 2-laing 355's each with XSPC dual top // (UN) 3G Brackets & X-Brackets // Swiftech Apogee XT // 2 x 120.3 & 2 x 120.2 Swiftech Rads//
    Wall Mount Build Log: http://www.xtremesystems.org/forums/...d.php?t=242186
    MM Extended Ascension Build Log:http://www.xtremesystems.org/forums/...d.php?t=212236[/SIZE][/SIZE][/SIZE]
    Jun 2007
    Chicago
    0
    Loose because the threading is too short or O-Ring is not thick enough?
    Quote Originally Posted by armeniandave View Post
    Mar 2008
    San Diego
    0
    The threads on the BP is actually a smaller diameter than what the international specification for a G3/8 thread should be. I went thru two from Gary before we realized that it was BP who made the thread smaller. That's why if you wrap enough tape on it it will work. The one from Petra's fit nice and snug right from the beginning and no tape was required. Gary does have the other one that is supposed to be for a Eheim that might work.
    This one works guaranteed:
    This one might also work:
    Jun 2008
    Northern Ohio
    0
    I could have sworn that early MCR's were 3/8" NPT not G3/8. Im not crazing thinking that those are different am I?
    I just want to put some of me compression fittings on my old MCR320
    Jun 2007
    Chicago
    0
    You are correct. I use 3/8 npt barbs on mine
    When I said G3/8 adaptors, I meant jam them in there with a little tape lol. A few people on here used G3/8 barbs on the Npt threading with a little tape. They said no leaks, but it's buyer beware at that point.
    http://img4.imageshack.us/img4/5827/dscf0064f.jpg
  18. #18
    Jun 2008
    Northern Ohio
    0
    Hmmm I thought NPT wa far enough off that it would not work. I will have to give that a shot. I just hate my current brass barbs I got at Lowes, want to put some fatboys or compressions on it. Thanks
  19. #19
    Moderator shazza's Avatar
    Aug 2007
    Back and forth between Florida and Maine
    3
    Thanks much for the heads up. I was about to tear down my loops to exchange the Petra's fittings for the BP ones (just to match the other fittings). I won't waste my time or chance a leak now.
  20. #20
    Jun 2007
    Chicago
    0
    I may do this too, but not with the initial G3/8 bitspower fitting. The initial bitspower fitting has too short a thread and imho will leak. I'd get what Dave recommended (g3/8 to g1/4 adaptor from petras) and then use a standard G1/4 bitspower fitting in the adaptor.
    The fitting that 2 people I know jammed into the npt was an aquaxteme G3/8 fitting which has a longer G3/8 threading. I suppose the Ek G3/8fitting would also work as well, since it also has long threading.
  21. #21
    Jun 2007
    0
    Guys, I linked to a (BSPT)R3/8" to G1/4" fitting in post #10. Why use parallel threads on a taper when you can use a tapered?
    Circles SucQ!
  22. #22
    Jun 2007
    Chicago
    0
    Quote Originally Posted by Waterlogged View Post
    Oops, I must of skipped over this one. Thanks for posting.
    Honestly, I don't it would do him any good since he wants to ditch the brass npt barbs for bitspower barbs.
    I have a nickel plating kit on the way, so this will work great, thanks
  23. #23
    Jun 2007
    0
    Quote Originally Posted by Eddie3dfx View Post
    It's already nickel plated.
    Circles SucQ!
  24. #24
    Jun 2007
    Chicago
    0
    My eyes are decieving me today.
    Anyhow, I will order these, thanks
  25. #25
    Jun 2007
    0
    Hate when that happens.
    Circles SucQ!
+ Reply to Thread
