I'm pissed off right now. Just a little, though.
As a bunch of you may know from following my recent threads, I have been dealing with dangerously high temps on my GTX280 VRMs, while using an MCW60-R2 and the Swiftech GT200 unisink to cool the RAM and VRMs, with two 1600rpm 120mm fans blowing directly on it.
With that configuration, my GPU temp at full load never broke 50C, but my VRMs (which made very good contact with the heatsink) would hit close to 150C, and was hampering my OC, which was damn good to begin with.
Now that I installed the DD-Tieton, my VRM temps are amazing. I have not seen them scratch 65C.
But. My GPU temp is HORRIBLE!! After a few seconds of furmark on stock speeds, it hits close to 80C !!! Now ever minor overclocks artifact.
WTF!? It seems the GPU block is elevated a bit too much from the GPU. I looked on some of the NCIX reviews for this WB, and I noticed one person report the same issue, but I attributed it to a faulty mount on their part.
I am 100% positive I have the block properly mounted, with all thermal pads and paste placed properly. There are no spacers or anything like that elevating the block from the card; it is as close to the GPU as physically possible. It seems like the built in standoffs are too long or something like that.
WHAT THE HELL? I am really pissed. What can I do in this circumstance? Any suggestions on how to possibly correct my issue?
