Tubing for a chiller
I recently tried my water chiller, but I quickly found out that my CHEAP tubing doesn't like the cold at all Will any of these two do the trick down to... say -35c (not sure it'll be THAT cold, but it's nice to have a little headroom)?
Tygon R-3603 3/8" ID 1/2" OD
or
Tygon R-3400 3/8" ID 1/2" OD
I see there are some 3/4" OD tubing, is it worth going for any of those instead? They're a bit more expensive, but if I have I'll go all the way
I have used tygon 3603 down to -20C for extended times with no problems
Thanks, exactly what I needed to know
- You may not post replies
- You may not edit your posts
Forum Rules
