These temps are with my Q6600 @ 3600 @1.42
As you can see my uncompleted chillier is able to keep my CPU 50c cooler than the mighty TRUE.
What power are you running the TECs at ? How warm is your room getting ?
Nice one. Looks like the work you put in is paying off. Have fun with it!
Are those the gigantic 62mm ebay TECs ?
What kind of temps can you get away with if you decrease the voltage further?
any specs on the TECs and voltage you're running would be great.
water to water cooling you don't see that very often.
wow very nice looking build thier !
exellent results also
[SIGPIC][/SIGPIC]
PENT E8400 batch #814A014 ...4.3 at 1.34v~4.7 at 1.45v
FOXCONN MARS
COOLIT Eliminator 7*c idle~27~38*c load $95bucks !
BUFFALO FireStix's ddr2-800 do 1200 eazy at 2.1v
OCZ 2x2 kit pc2 8500 - 1066 @1069 atm
Quattro 1000W
Radeon 2-4850's in crossfire
OCZ Vertex SSD thanks Tony!
ALL PIPED INTO HOUSE AIRCOND ;}
*QUANTUM FORCE* saaya & sham rocks !
*REAL TEMP*
At least you've got some Xtreme software now for working in Xtreme situations! "Unclewebb" rocks !
*MEMSET* Felix rocks !
*SUPER TEC MAN* UncleJimbo rocks !
OVERCLOCKERS MAG..http://www.xtremesystems.org/forums/...d.php?t=197660
Sorry to dig up an old thread, but Sonic, here are a few questions for ya :
1- what are you using to power your t.e.c.s ?
2- what are you using to cool down the hot plates?
3- do you have any more pics? It's a pretty cool concept...
Intel Q9550 : Dtek Fuzion v2
DFI DK P35-T2RS : EK NB-SB5
4gb Mushkin Ascent PC2-8500
XFX GTX 275
Azza Solano : MCP355 w/ XSPC res-top, Swiftech MCR220 + MCR120
1 two 24 volt 320watt psus . it uses about 450watts
2 3 GTS 240's with 2000 rpm fans (so not that much when you do the numbers)
3 yes
