+ Reply to Thread
Results 1 to 5 of 5
Thread: some advice for my WC?
    Registered User cucurucho's Avatar
    Oct 2007
    Córdoba - Argentina
    0
    First to me
    i´m working in my cosmos to watercool my future system.
    i alredy have
    MCP 655
    HW Labs Stealth 360 xflox (planing 3 S-Flex 1600/1900RPM)
    MCW60 (for a 8800GT with uni-sink modded)
    MCW30
    MCR-RES
    tubing 1/2 ID 3/4 OD
    and i ordered to gary from sidewinder a GTZ with Ci7 mount kit, unfortunately he has no stock for de munt kit, so i planning to get the fuzion v2 and some 45° compression fittings for fesser
    the loop will be pump->rad->cpu->nb->gpu->res->pump
    i´m planning to get a i7 oced at 4Ghz.
    Will i have enough rad for the cpu and gpu?
    Will the pump handle the restriction of the entire loop?
    Xtreme Enthusiast exemay's Avatar
    Oct 2008
    0
    hmmm, the best way would be to have two loops. one CPU +NB and one for the GPU. id always recommend a seperate loop for GPU, just because i dont like the heat dump from it in the same loop as the CPU....it will work having it all in the same loop with a 360 rad
    as for the pump, it will work, aslong as you dont have miles of tubing
    Quote Originally Posted by kinghong1970 View Post
    yea.. i need help... seriously......last time i went to the bathroom, it seems that the male has the pecker that pokes the female, right?
    i'm confused...
    Quote Originally Posted by lennox View Post
    holy cow do you really run 1/2" tubing without clamps? that's like banging a prostitute without a condom!
    Lian Li V2000B Special Water cut: DFI LanParty X48 LT T2R : Q6600 @3.21 ghtz : 2x Samsung Spinpoint F1 32mb cache 1tb HDD's : HD 4870x2 : 4GB domminator : Swiftech GTZ block : PA120.3 : DCC 18w res top : DCC 18w res top : EK FC 4870x2 :
    Current Project:
    http://www.xtremesystems.org/forums/...d.php?t=214295
    Oct 2007
    Córdoba - Argentina
    0
    Thanx exemay, I was doing my homework (reeding XS ) and i find that talonman has a increase of 8° on load adding a GTX280 to his loop (link), this is a considerable increase
    But i asume that my 88GT will be adding a lot less heat to my loop, however im thinking to add a second rad between de CPU and GPU block, That should help to keep the loop cool and is much cheaper that add another pump/res/rad to meka double loop (maybe i will do double loop in the future)
    Xtreme Cruncher Grinch's Avatar
    Jun 2005
    Lakeland,FL
    0
    2 rads or get get a pa120.3?
    750W Thermaltake Modular PSU
    DFI UT X58-T3eH8
    Core i7 920 @ 20 X 200 1.325V
    CORSAIR XMS3 DHX 4GB (2 x 2GB) DDR3 1600
    768 MB EVGA 8800GTX
    1 X 36GB WD Raptor
    2 X 150GB WD RAPTORS
    1 X SpinPoint P Series SP2504C 250GB
    1 X Maxtor 6L300S0 300GB
    16 X NEC DVD Burner
    7 120mm Yate Loon LED Intake Fan
    4 120MM Yate Loon Exhaust Fan
    28" HANNSPREE Monitor
    Watercooling Loop:
    1 X PA120.3
    1 X PA120.2
    2 X Laing DDC's w/EK-DDC Dual Turbo Top
    7 X Yate Loon Blue LED Intake Fans
    4 X Yate Loon Blue LED Exhaust Fans
    1 X Swiftech GTZ
    1 X GPU EK Fullcover Waterblock
    1 X XSPC Dual Bay Reservoir 5.25" with Bubble Window
    Oct 2007
    Córdoba - Argentina
    0
    adding a PA 120.1 on the Rear exhaust of the case between the cpu and gpu will be enough?
+ Reply to Thread
