Is it intel or amd? And which one is it?
2-VIOTEK FI24D V2 24-Inch QHD Gaming Monitor with IPS Technology, ASUS ROG STRIX B550-A GAMING AM4 AMD B550, CORSAIR Vengeance RGB Pro 16GB (2 x 8GB) DRAM DDR4 3200, MSI GeForce GTX 1660 Ti 6GB GDDR6
AMD RYZEN 5 3600 6-Core 3.6 GHz, Asus BW-12B1ST Internal Blu-ray Writer SAMSUNG 830 Series 2.5" 256GB SATA III , HITACHI Deskstar 2TB, 2 - Western Digital Black -2 TB HDD
Super Flower Leadex III 650W 80+ Gold, AMD AM4 Wraith Prism LED RGB Cooler Fan, Windows 10 Professional Retail, Fractal Design R4 case
q9550s? isn't that the energy efficient model from intel?
looking to overclock or use with a quiet or low profile cooler? the chips with less cache will conume less power and produce less heat, the q9550s is intended to business use and you will probably have a hard time finding one for sale. my first quad was a q9300 and it was a screamer.
Which consumes less power. The 860 or the 920?
i would expect an AMD chip to be cooler running
SYSTEM
i5-3750K @ 4.6ghz - ASRock Z77 Extreme4 - 16GB Samsung DDR3 - Sapphire R7 370 Nitro 4GB
Water Cooling
EK Supremecy - DDC-3.2 w/XSPC Top -Swiftech MCR320-QP - EK Multioption 150
That may be but I want to know which would consume less power between the 860 or the 920.
+1 for AMD chip, they run cooler.
But as for INTEL, i think the Q8xxx are the coolest one.
BTTB - Gigabyte Z87X-OC - WCed I7 4770k - 2x8gb Ballistix 1600mhz - Zotac GTX 780
Asus Xonar Pheobus - OS -> Toshiba Q 256gb - Games -> 2x Agility 4 256gb Raid0
Corsair HX850 - Tecnofront HWD BenchTable - Asus VE278Q 5760x1080
Serveur - Asus Z77m PRO - 2500K - NH-C12P - 4x4gb G.Skill Ares 1600mhz
Agility 4 128gb - Corsair CX430M - 1TB Black - 2TB green - 2TB Red
KatPat - Gigabyte 990FXA-UD3 - FX-8320 - PH-TC14CS - 2x4gb Viper 1600mhz - GTS 450
Samsung Evo 120gb - Corsair HX750 - Bitfenix Survivor White - Asus VE247H
i5 750 is the coolest running.
Current: AMD Threadripper 1950X @ 4.2GHz / EK Supremacy/ 360 EK Rad, EK-DBAY D5 PWM, 32GB G.Skill 3000MHz DDR4, AMD Vega 64 Wave, Samsung nVME SSDs
Prior Build: Core i7 7700K @ 4.9GHz / Apogee XT/120.2 Magicool rad, 16GB G.Skill 3000MHz DDR4, AMD Saphire rx580 8GB, Samsung 850 Pro SSD
Intel 4.5GHz LinX Stable Club
Is 860 or 920 the lowest power consumer?????????????????????????????????????????? ????
I dont know what the Q9XX0's are doing but on my lowly Sunbeam Core Contact Freezer (5-6c higher temps than the TRUE/Mega) my AMD Phenom II 965BE Chip peaks at 57c load @ 3950 Mhz with 1.520v...54c if I leave the CPU-NB ( i7 uncore) at stock.
To answer your question, the 860 comsumes less power but I don't think runs much cooler than the 920.
Smile
