+ Reply to Thread
Results 1 to 7 of 7
Thread: PSU whinning
    Sep 2006
    0
    PSU whinning
    so okay, my 3 year old ULTRA 500W psu started whinning recently. Do you guys know why this happens? Any way to fix it? I also recorded the sound if it helps: http://www.youtube.com/watch?v=qmdRQ_qb_8c
    Specs in sig
    Jun 2008
    0
    whining PSU's are never a good sign. could be going bad or theres a massive accumulation of dust buildup in it.
    i would start looking for a replacement, ASAP
    Intel Q9450 | Gigabyte X48-DQ6 | 2x WD VRaptor 150G RAID 0 | 4GB OCZ PC9600 FLEX | ATi HD4870x2 | NEC 2490WUXi | Auzentech X-fi Prelude | Antec 850W SS | Ikari laser mouse | Logitech G11 | CM Cosmos
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    20
    thats the sound that they make right before they die, and for your next one get a reputable brand. im surprised that that ulra lasted u that long i killed a bunch of those with a 2.9GHZ clawhammer 939
    3770k, M5E, kingston 2x4GB cfr
    samsung 2TB F4EG, samsung 840 250GB , CM690II, corsair 750tx
    Jun 2008
    0
    Quote Originally Posted by zanzabar View Post
    true dat, ultra's are not known for their reliability
    Xtreme Member CodeNinja's Avatar
    Jan 2008
    Port Orange, FL
    0
    Whining is usually either a transformer going bad, or a capacitor going bad.
    Time for a new supply, my friend! It -might- be fine for a while, my computer ran for about 6 months on a whiny supply. But if it does pop, don't be horribly surprised if it doesn't damage other hardware.
    Asus P6T | Corsair H100 | i7 920 @ Stock| 6GB Corsair DDR3 1600Mhz |
    EVGA GTX270 SC 4GB | 4x WD Caviar Black 640GB RAID10 Array | CoolerMaster Centurion 590 |
    Corsair 850HX Modular PSU
    Apr 2008
    0
    i know i killed a 550W in less than 6 months
    amd 720
    M4A78T-E
    i gig of crap
    visionek 4850
    seagate 320 GB 7200.10
    WD 640 GB
    swiftech MCR320 swiftech MCP355
    Apogee GTZ
    XPSC Restop
    Quote Originally Posted by road-runner View Post
    I can say one thing I learned out of all this, I am not buying any Intel SSDs thats for sure...
    Sep 2006
    0
    thanks guys, I just ordered a Corsair TX650W as a replacement, should be here in ~5 business days
+ Reply to Thread
