What's the wire gauge for the fans? 24/26?? I want to extend all of my rad fan wires about 30"-36" to route them around the inside edge of my case. Should I go with once gauge larger for the extended runs?
I believe the 1/8 is what you're looking for.
I also believe that the true gauge on the wires is 26, not that it makes a difference. Just FYI.
Project Obsessed being updates currently after a 2 year hiatus FML.
• - Asus Maximus II Formula • - Intel Q6600 G0 @ 3.6Ghz @ 1.272v • - Visiontek 4870 512MB • - 4GB Mushkin Redline @ 960Mhz • - Corsair HX620W Modular Power Supply • - X-FI XtremeMusic • - MM U2FO • - Gateway FHD2400 24'' w/ optional speakerbar
Watercooling Loop : Custom loop. Will update later.
New Project on the Horizon (with sponsors to boot)
- in reference to Project: MithrilOriginally Posted by BullGod
The Cardboard Master Crunch with us, the XS WCG team
Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
Good information here. I am planning to run the wires for the fans (on the rear of the case) to the front of the case where the fan controller is going.
Black Dragon
MM Extended Ascension - Powder Coat Black
Core i7 920 | 12GB Corsair DDR3-1600 | eVGA x58 | 3 x eVGA GTX285 SC | 2 x 640GB WD Black in RAID 0 | TT Toughpower 1200W Modular PSU | 24" LG Monitor | Vista Ultimate x64
WC Loop 1: Swiftch MCR320 | Laing DDC w/ XSPC Res Top | Swiftech GTZ
WC Loop 2: 2 x Swiftch MCR320 | Laing DDC w/ XSPC Res Top | BP Black Freezer NB/SB | 3 x Koolance Fullcover Waterblock
you could run a thinner wire for the rpm pulse
I was wondering the same thing.
Would this stuff be too thin?
that would be fine... thats a good deal on the wire... and theres a jaycar just round the corner from me in northbridge
just remember to only connect one fan into the pulse wire
Hahah good, cos I recently bought 4 rolls of each colour, plus a dozen 3pin headers and some soldering supplies.
Last thing I'm trying to find locally is the motherboard KK header plugs (at least I think they are KK).
By this chart:
http://www.powerstream.com/Wire_Size.htm
If i wanted to wire all three of my rad fans together with a .25 amp draw per fan, I would need 22 Gauge which is rated at .92 amp working load. (leave some overhead room) 24 gauge is rated .72 amps working load.
Found this twist for $5...
Overpriced. Guess ill have to get it in 3 - 25' spools for $4 each. I have a few separate case fans that i will use the RPM wire.
