To make things as short as I can, I recently managed to screw up a my D5 pump and ended up just taking the whole loop apart, cleaning the blocks of what oxidization I can, and waiting on it.
At this point, I'm thinking about just a new res (EK 250), Bitspower 45 rotaries to help my loop "flow" better," and a new pump.
In this regard, I'll list a couple queries that came to my mind.
1: Is the EK res easy to mount? I've seen a ton of people with it mounted in all sorts of weird places, so I figure it must come with some decent mounting hardware. If not, any suggestions for mounting hardware I can buy? I'm not handy with a drill or anything, if something needs tearing apart to work, I probably won't even do it.
2. I hardly need to ask this, but are BP 45 rotaries trustworthy? I'm not in the mood for more leaking.
3. For a pump, should I get a D5 or DDC3.2? It seems to me the D5 would be smarter as with the 3.2 I'd then get the XSPC mod top, sending it nearly into the $100 range. And then I'd probably still need to buy a stand as the DDC3.2 doesn't come with one. Or do I not need a stand, I've just heard a lot of heat issues with the 3.2. Again, ease of mounting is kinda important to me, I'm a lazy man.
With that out of the way I had one other thing bugging me.
4. I considered getting the Swiftech MCW60 for my GTX 260(216) along with the unisink. Could a MCR320 radiator with Zalman F3 fans (I think that's what they're called ) be enough for an overclocked Q6600, X48/38 chipset, and a G200 card?
At this point I'm thinking no, especially as I live in Phoenix where the ambient temp is usually about 27 - 29. But, I'm open to advice as I don't claim to be anything short of a watercooling novice.
Thanks!!!
