There it is my 94 supra turbo with 70k miles, bought it when I was 20 and I don't think I'm going to sell it anytime soon.
Specs
Engine
ETS 72mm turbo kit with precision turbo 4in mp and dp
BL Fuel system with dual 255 denso supra pumps and 1000cc injectors
HKS FCon V-Pro piggied with stock ecu tuned for pump gas for now
ATI crank damper, with greddy timing belt (issues with 2jz crank damper cracking)
Jun cam gears
Removed EGR
Rerouted heater core hoses
Greddy 4 row intercooler
PWR Radiator
HKS Titanium 4in
Suspension/Brakes
Tein RA coilovers
TRD front strut bar
Cusco rear carbon strut bar
Full r2 bushings for all control arms
R2 steering rack bushings
Stock calipers with hawk hps pads
TRD stainless lines
Future engine upgrades completed
GSC S2 274 cams/supertech dual valvesprings/ti retainers/locators/locks/ferrea valvestem seals
Spal 7.5 fan on the tranny cooler -6 lines to the cooler
-8 lines to catch can setup
twins turbo waterneck rotator
New Weldon FPR (aeromotive broke)
AEM UEGO (innovate broke)
Retune on vrpo with e85 and pump 92
Possible in the future to switch to 2000cc Injector dynamic injectors
Will upload some pics tonight, and we are discussing trans options now lol.
Dyno at PSI
http://www.youtube.com/watch?v=q_EKePw9d4c
UPDATE FOR 2011 Coming soon.
So up date for 2011, started around Oct of 2010, got back from trip to China, and figured I need to do something so I won't be bored and ended up with this.
Then it snowballed and the project starts, huge order of new oem toyota parts.
Clutch pedal built
45 Dollar per bottle tranny fluid lol.
Driveshaft shop goodies showed up
Billet spacer mounted on trans
Six speed rear end showed up this is the pic after its opened cleaned and resealed and ready to go on the car.
Mess inside
Bye Bye auto shifter
Ouu my clutch showed up didn't have quite the budget for the triple version so twin will have to do for now.
Trans with billet shifter fork bushings and TRD trans mount mounted.
Mess of old auto parts
Hole for the six speed tunnel cut out with sawzall
New six speed trans tunnel mounted riveted and seamsealed.
And done
Now this took 28 days to complete working afew hours a night during regular days and couple hours a day on weekends. Overall it was smooth I skipped a lot of other pics since no one was there to take pics such as drilling holes to mount the master cyclinder and clutch pedal as well as removing old trans and mounting the new one etc.. It some of it was such a PITA I was like why am I doing this lol but in the end it was worth it.
So moving on it was just barely thanksgiving of 2010 when I was wrapping up the project and GF asked what I wanted for xmas knowing she don't make much moola I throw out the idea of changing the looks of the car and ditching the body kit so around xmas time this shows up.
Shine auto Ridox kit with CF accents
Test fitted, but you can't tell the CF accents
Painted and now you see the accents
All done and crusing around
