I'm doing a modification on a cooler to be able to use in the Xbox 360.The plan is simple,attach a copper plate to the copper base of the heatsink and them attach this copper plate to the screw holes,making contact with the die.My initial plan was doing that with some thermal adhesive,the contact area will be huge,so I'm sure it could hold the weight of the heatsink,but using thermal adhesive will surely not be as effective as soldering,the base has no holes,so if the material for soldering has a low melting point I can just melt it over the base and then attach the plate.
