Hello guys,
I got a little question about my watercooling loop. I am thinking is it worth placing the pump right before the CPU Block?
I got these components:
CPU Block: Swiftech Apogee GTZ
Pump: Laing D5 (Swiftech MCP655 branded)
Reservoir: Swiftech MCRES Micro Rev.2
Radiator: Airplex XT 240
I got 2 ideas about loop management:
1) Res >> Pump >> Rad >> CPU Block
2) Res >> Pump >> CPU Block >> Rad
D5 puts ~15-24 watts of heat in loop. So here is my question: which loop will give me better results? Is it worth it to place Rad after the pump to dissipate that heat?
Or will the second loop give me better results, cause my CPU Block is impingement design and will receive benefits from more flow rate and pressure?
As far as I concluded, D5 will increase water temps by <0.5-1 C.
If so, then I think that placing the D5 just before GTZ will give me the better results.
What do you think?
P.S. I have not received the rad itself yet to test the loops myself.
