Processor: Intel Core i7 990X
Motherboard: ASUS Rampage III Extreme
Memory: Corsair CMT6GX3M3A2000C8
Video Card: MSI N680GTX Lightning
Power Supply: Seasonic S12 650W
Case: Chieftec BH-01B-B-B
but F3's are sleeve bearing, not entirely ideal for flat mounting
i5-750 w/ Thermalright Ultra120X
Coolermaster HAF-932
MSI GD65
2x2GB G.skill Cas7 1600MHz
Sapphire HD6870
Western Digital 640GB.AAKS
2x Samsung F1 1TB
2x Samsung SLC 64GB SSD
Pioneer DVR-212BK
Corsair HX620W
Creative X-Fi Xtreme Music (dead, using onboard -.-)
LG W2286L
looking at vapors fan roundup 2 your are right! when i made my decision, i focused on vapors first comparison and missed the zm-f3. may be it was not even included at that time. so i decided between noctua and sflex.
anyway i tried my best to filter out the following three fans from vapors radiator test of round 2: sflex-e (1200rpm) sflex-f (1600rpm) and zm-f3 (1800rpm). used the radiator test as i'm not interested in open air results. guess most ppl are running such fans on a cooler or rad.
as you can see, surprisingly the sflex-f and zm-f3 are pushing slightly more air at the same noise level than the sflex-e. would have expected at least the two sflex are in line as they are mechanically the same!
the zm-f3, on the other hand, is almost in line with the sflex-f, producing a little bit less noise when it pushes around 29cfm to 33cfm, BUT is able to scale up all the way to 54cfm!
looking at this figures and of course the price (sflex-f: 12.5eur, zm-f3: 7.8eur) i would recommend the zm-f3 too!
dont know the lian li stock fans, so i have no idea how powerful (cfm rating) they are.
i know the faneq settings on abit boards pretty well. use it on two systems here. if you connect your fans to the abit board you can go with any of this fans and run them at about 8V, spinning it up when temps rise!2) I also have an Abit IP35-Pro. Supposedly it has a FanEQ setting. Anyone used it?
anyway, if you are running the fans in open air you probably can go with lower speed fans like the 1200rpm, 1000rpm or even 800rpm fans. i try to use as less fans as possible. on my air cooled rig, i use one fan on the cpucooler and one to move fresh air to the vga card. no need for extra fans in my situation. are you sure you need 2 extra case fans?
I will be replacing be two current (intake and exhaust) case fans with Zalmans. I went in to the FanEQ BIOS (currently have BIOS 17) and set it to 8V but nothing seems to have changed. It was hard to see the header label on the mobo so I enabled all of the fans in the BIOS. Any idea?
Thanks for the help everyone.
