+ Reply to Thread
Results 1 to 13 of 13
Thread: destroyer
    Xtreme Addict msimax's Avatar
    Jun 2005
    NYC
    0
    destroyer
    i just looked up a review of this board and they say 8 phase pwm can you confirm saaya
    also whats the highest vcore allowed in the bios and does all the sliders in ntune work with this mb
    thanks
    Amd Nvidia/Ati -3dmark06 scorebord revisted
    asus L1N64-ws or /b depending on bios chip
    4x1gig 8500 gkill bpk
    2x opteron 8224 @ 3.8ghz
    http://www.xtremesystems.org/forums/...&postcount=236
    vga= 8800gt
    winxp pro
    custom chiller -31 water
    2x dtek fuzions
    bix3-with x3panaflo hi output
    antec 850 quattro
    heat under msimax abitmax and dfimax
    Xtreme X.I.P.
    Nov 2002
    Shipai
    1
    i dont think all sliders work, but ask fatalbert
    ntune isnt... perfect :P
    it cant be compared to amds overdrive... its a shame that overdrive only works on amd chipsets...
    supposedly an older beta is floating around that works on destroyer, but that was before my time and i dont know about that...
    highest vcore is 1.7v, back then for am2 that was more than enough and the board has ovp implemented inside the pwm chips, which apparently cant be bypassed :/
    but for daneb 1.7v is more than enough for air and even water afaik, its only on ln2 that you need 1.9v to fully max out the chip from what ive seen.
    oh and its 5 phase, not 8 phase!
    Jun 2005
    NYC
    0
    thanks
    vga= 8800gt
    winxp pro
    2x dtek fuzions
    antec 850 quattro
    Xtreme Enthusiast FatAlbert's Avatar
    Nov 2006
    Poland / Rypin
    0
    Quote Originally Posted by saaya View Post
    isn't good news
    I saw 1.8 max vcore in bios
    1.8 is good for 5.5 @ ln2.
    Schedule of Live Extreme Overclocking - info Thread
    Quote Originally Posted by K404 View Post
    "My Backup is bigger than Your Backup"
    Xtreme X.I.P.
    Nov 2002
    Shipai
    1
    yeah, sux huh? the engineer who built that board seems to be less experienced than the one who worked on BlackOps and BloodRage
    bios options are available up to 2v, but anything above 1.7v real triggers ovp...
    Nov 2006
    Poland / Rypin
    0
    make sure next board on nf will have 1.9 vcore and 2vmem
    Xtreme X.I.P.
    Nov 2002
    Shipai
    1
    only 1.9 and 2v?
    all outta gum G.Foyle's Avatar
    Dec 2006
    Poland
    20
    According to ISL6324 datasheet, OVP limit could be pushed to (VDAC + 500mV) which is 1,95 V if I am correct?
    It would be nice to solve this problem as we are preparing to do some 3D benches with SLI and Deneb...
    www.teampclab.pl
    MOA 2009 Poland #2, AMD Black Ops 2010, MOA 2011 Poland #1, MOA 2011 EMEA #12
    Test bench: empty
    Nov 2006
    Poland / Rypin
    0
    only 1.9 and 2v?
    1.9v for cpu or if PWM will be strong as in blackops 2v will be enough
    2v for ddr3
    as I know next nforce will use DDR3 so "only" 2v
    btw
    sayaa can you tell us about next amd boards ?
    Nov 2006
    Poland / Rypin
    0
    Quote Originally Posted by xoqolatl View Post
    mozesz podać jakieś szczegóły ?
    co i jak ?
    Dec 2006
    Poland
    20
    O OVP:
    http://www.intersil.com/data/fn/fn6518.pdf
    O benchowaniu: sami za dużo nie wiemy jeszcze pewnie jutro, SLI GTX285
    www.teampclab.pl
    Test bench: empty
    Nov 2006
    Poland / Rypin
    0
    sayaa, did you tried or can you try an idea of xoqolatl ?
    look like possible to do. But I remember when you said "there is no ovp mod"
    Xtreme Mentor demonkevy666's Avatar
    May 2008
    cleveland ohio
    24
    http://www.xtremesystems.org/forums/...9&postcount=47
    MOB: ASUS M2N32-SLI DLX Bios 1503
    a.o.d 2.0.9
    http://downloads.guru3d.com/download.php?det=1792
    HAVE NO FEAR!
    "AMD fallen angel"
    "Behold the gaseous stench of Skeletor's breakfast burrito!"
    Quote Originally Posted by Gamekiller View Post
    You didn't get the memo? 1 hour 'Fugger time' is equal to 12 hours of regular time.
+ Reply to Thread
