Radeon driver on FireGL
I got a FireGL 3100 for free, and it seems to have an issue with Direct3D. Is there anyway I can force the normal Radeon driver to run it? Like modify the the INF?
It would also help If I could figure out what Radeon card the FireGL 3100. Best I can find is either X600 or X300
Fold for XS!
You know you want to
I am Xtreme
Check what memory the card has, then go to mvktech and download some X300 and X600 BIOS files. A little experimenting will be needed but by force flashing the card should be able to be used as one or the other. I'm pretty sure the Fire GL is a X600, so I would try those BIOS files first. Naturally, remember to make a backup of the current BIOS on the card and have a PCI card handy in case a flash doesn't go well.
- You may not post replies
- You may not edit your posts
Forum Rules
