i had a Q6600 and the usual apps could read the CPU temp
i now have a q9400 but nothing seems to be able to read the temp any more?
I have done a bios update but that hasn't helped
any idea guys ?
any idea guys ?
Have you tried Real Temp
Its made by Uncle Webb who is part of XS its an awesome little program
~ Little Slice of Heaven ~
Lian Li PC-A05NB w/ Gentle Typhoons
Core i7 860 @ 3gHz w/ Thor's Hammer
eVGA P55 SLI
8GB RAM
Gigabyte 7970
Corsair HX850
OZC Vertex3 SSD 240GB
CPU temp is TCase, usually you can ignore that. All you need is to know your cores temperature. Take latest RealTemp and play with it. In this release you have now a build-in plugin for RivaTuner if you use Riva.
If it ain't broke... fix it until it is.
yes i have and it doesn't work it just shows the temps stuck at whatever
Aaa, you have stuck sensors then. Try a CPU Cool Down test and post a screenshot.
the beta one has the same issue
how do i do that ?
Yeah show us a screen shot and let me find the link to the real temp thread so incase we cant help uncle webb would be able to most likely
EDIT
here is the link to the RealTemp thread
http://www.xtremesystems.org/forums/...d.php?t=179044
eVGA P55 SLI
8GB RAM
Gigabyte 7970
Corsair HX850
see 100% at low temps that dont move
Yeah you got stuck sensors. I do not know if you can do anything about those though.
eVGA P55 SLI
8GB RAM
Gigabyte 7970
Corsair HX850
Press Sensor test, point to prime95 exe (choose Small FTTs) and hit Start. Take a break for 10 minutes and you'll see something like this.
You can try Core Damage to see if your temps are moving. I have a guy in our forums with sensors stuck at 51°C.
hooh, sad story, mate
Intel Q9650 @500x9MHz/1,3V
Asus Maximus II Formula @Performance Level=7
OCZ OCZ2B1200LV4GK 4x2GB @1200MHz/5-5-5-15/1,8V
OCZ SSD Vertex 3 120Gb
Seagate RAID0 2x ST1000DM003
XFX HD7970 3GB @1111MHz
Thermaltake Xaser VI BWS
Seasonic Platinum SS-1000XP
M-Audio Audiophile 192
LG W2486L
Liquid Cooling System :
ThermoChill PA120.3 + Coolgate 4x120
Swiftech Apogee XT, Swiftech MCW-NBMAX Northbridge
Watercool HeatKiller GPU-X3 79X0 Ni-Bl + HeatKiller GPU Backplate 79X0
Laing 12V DDC-1Plus with XSPC Laing DDC Reservoir Top
3x Scythe S-FLEX "F", 4x Scythe Gentle Typhoon "15", Scythe Kaze Master Ace 5,25''
Apple MacBook Pro 17` Early 2011:
CPU: Sandy Bridge Intel Core i7 2720QM
RAM: Crucial 2x4GB DDR3 1333
SSD: Samsung 840 Pro 256 GB SSD
HDD: ADATA Nobility NH13 1GB White
OS: Mac OS X Mavericks
burebista that shows a variance of 0 across all cores for me
Damn, not even Core Damage or LinX are able to move your sensors?
no i'll try it on another MBM and re build it. Not that that should make a difference.
the cPu works fine on another mbm
ok so replacing the mb didn't fix the problem and i got a new Q9400 and that didn't solve it too. im selling my q9400 and keeping my Q6600
