    X
    Subscribe to New Ads!
    Receive weekly ads in your inbox!
Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: Q² Project by The-Fox
    Mar 2005
    Preface:
    This project is sort of a sequel to a previous project I had with my Lian Li G70.
    This time the Hardware and cooling were upgraded to the highest degree and basically I spared with nothing and tried to put my best with everything here.
    The main objective: To achieve the highest level of performance while maintaining low noise and keeping everything aesthetically pleasing.
    The Hardware:
    • CPU- Intel Core i7 920
    • Motherboard- Asus P6T Deluxe
    • RAM- OCZ DDR3 Platinum 1333Mhz 7-7-7 3GB Triple Channel
    • GFX- Sapphire 4870X2
    • PSU- Coolermaster Silent Pro 700W
    • Storage- Perc5/i + WD 640AAKSx4 RAID0
    • DVD Burner- Asus 2014L1T
    • Case- Lian Li G70 Silver w/window (or what left of it )
    The Cooling:
    CPU loop:
    • Block- Swiftech Apogee GTZ
    • Rad- TFC Feser Xchanger 480
    • Pump: Swiftech MCP655 Vario + DetroitAC top.
    • Tank: EK Multioption RES 250 Rev.2
    • Fittings: Koolance 1/2" Compression fittings + Bitspower 45 degrees rotary
    • Tubing: Tygon R3603 1/2"
    • Fans: Yate Loon D12SL x4 @ 1350RPM
    GPU Loop:
    • Block- EK-FC4870 X2 Nickel
    • Rad- Swiftech MCR320
    • Tank: EK Multioption RES 150 Rev.2
    • Fans: Yate Loon D12SL x3 @ 1350RPM
    The Mods:
    - The upper panel was milled to accommodate the quad radiator and it needed to look nice.
    In addition, there was a precision issue that required specific placement of the rad in +- 20mm as the chassis/frame of the case was limiting.
    - The lower panel, which is a part of the chassis, was cut to accommodate the triple rad.
    - Duo to the lack of quad radgrill and since I wanted to have filters installed, I ended up using 4 simple Alu filters instead of a radgrill, its pretty cheap and keep dust away from the rad, cleaning the filters is a breeze.
    - Custom made Power Sata cable to connect 4 of the HDs and the DVD Burner, have the lowest profile using pass through connectors.
    - Sleeving of all the cables in the system.
    Misc stuff:
    - Scythe Kaze Master Multi Channel Bay Fan Controller - Silver.
    - 2 liquid thermal sensors, 1 for each container. they are connected to the Panel which displayed the temperature in realtime.
    - 2x12"Cold Cathode, Blue/Red.
    - Liquid Cooling is a mixture of: distilled water+Feser Color (Blue/Red)+Feser Ant Corrosive additive.
    - Lian Li EX-34NA Expansion Hard Drive Kit - Silver To accommodate the 4 Hard Drives in the upper 3x5.25" bays and clear the needed space to the lower rad.
    - 3x3Pin fan cable splitters to control all of the rad fans from the Fan control unit.
    - 2 leds (red/blue) to light up the liquid inside every water tank.
    - 2xUnDesign 360 Mount for D5.
    - Petra Jell stuff for the 2 D5 pumps.
    - Acoustic Damping material by: AcoustiPack™ ULTIMATE.
    The Photos:
    Hardware conference:
    The Mobo:
    The CPU:
    The Video Card:
    The RAM:
    Starting to break down the Video Card:
    Blood Red:
    The Mighty rad:
    The panels:
    Starting to assemble the endless number of parts:
    By TheFox7
    Fast Forward to the Finale result:
    Closing everything up:
    My current 24/7 setup with max load temps using 10 LinX loops:
    All in all, I am very pleased with the result.
    The computer is very quiet, most of the noise is just air moving and nothing else.
    I can turn off 2of the fans on the CPU rad and 2 of the fans on the Video card rad and it will still work great under moderate load with very minimalistic noise.
    The OC is respectable and with temps that can be called "sane" and acceptable for 24/7 work.
    PC: Intel Core i7 920 D0 | Kingston Hyperx T1 6GB 2000Mhz 8-8-8 RAM | Foxconn Bloodrage GTI | Sapphire 4870X2 | Perc 5/i - WD 640AAKSx4 RAID0 | Asus 2014L1T | Dell 2407WFP | Lian Li G70 Silver Watercooled
    WaterCooling: Q² Project by The-Fox
    CPU Loop: Swiftech Apogee GTZ | Feser X-Changer 480 | Swiftech MCP655 Vario w/ DetroitAC top | EK Multioption RES 250 Rev.2 | Tygon R3603 1/2" | YL D12SL@1350RPM x4
    GPU Loop: EK-FC4870 X2 Nickel | Swiftech MCR320 | Swiftech MCP655 Vario w/DetroitAC top | EK Multioption RES 150 Rev.2 | Tygon R3603 1/2" | YL D12SL@1350RPM x3
    Sep 2008
    The Magnificent Mile
    This is a really nice build - very clean - I love those fesers & the 45 degree fittings -
    nice choice going w/ the Alu filters - they look fantastic
    Oct 2008
    NY
    I really like your build. It looks great and you have some high performance parts. The one thing I would do is remove the kink coils. I think the tubing would look a ton better without them.
    heat
    TJ07-Ultra 1200W-E8400-Rampage Formula-4870-4gb G.skill-74gb Raptor-500gb Seagate-Windows 7
    Apogee GTZ-XSPC Razor-DDC3.2 w/ XSPC top-PA120.3-MCR220-EK 250 res
    Oct 2002
    Charlotte, NC
    Excellent craftsmanship, pride and everything else. The sign of a successful build IMHO is the simply whether the builder took a lot of pride in what he did. Very obviously the case here (no pun!).
    Anyway, I've got a 1980's BMW oil cooler that I was gonna use on my 5-series when i put the turbo kit on it. however, i ended up going with an Earl's setup. Maybe i can run some solvent through that baby and use it for my new i7 920 rig..... it looks almost EXACTLY like the one you have there. I might make it completely external though. Just a thought right now.
    what's the prevailing wisdom among the water cooling afficionados here about using aftermarket automotive performance parts? oil coolers and other heat exchangers like this, -AN vs NPT fittings, Aeroquip hose, etc etc. i know for a fact that some of the auto-grade wire loom is cheap as hell, tightly woven and WAY better than any of the braided stuff i have seen in the PC market (perhaps my exposure is limited).
    I'd love to use some NASCAR grade quick disconnects for an external radiator (for all my connections frankly). those things are uber-expensive though. obviously this kind of part is overkill for dissipating 300watts of heat, but hell...on this board? no such thing as overkill.
    ASUS P6T6 WS REVOLUTION | i7 920 @ 4.0 @ 1.28v | TRUE 120 Extreme | 12GB Corsair @ 1603 @ 1.66v @ 8-8-8-24-1T | BFG 8800 GT OC | Corsair HX1000w | OCX Vertex 60G | 2x WD 1TB RE3 Intel RAID1 Data
    DFI LP SLI-DR | X2 4400 @ 2650 @ 1.4v | 2GB Mushkin Redline 3-3-2-8 1T @265 | BFG 8800 GT OC | Seasonic S12 600W | WD 150GB 10k & friends | Koolance RM-3U H20
    what fluid is that?
    is that feser one?
    Mar 2005
    Quote Originally Posted by RussianBlue View Post
    Thanks for your kind words buddy
    Quote Originally Posted by ILikeCosmosS View Post
    what fluid is that?
    is that feser one?
    Close, its a mix of distilled water + Feser UV color additive+ Feser Anti corrosion additive.
    Oct 2005
    Bad idea on the link, all Al. Don't want that. You have to be careful with those types of radiators because they are not worried with corrosion from different metals the way we are.
    http://www.xtremesystems.org/forums/picture.php?albumid=144&pictureid=327
    Dec 2008
    wow sweet... im thinking of setting up the same thing..
    Jan 2005
    nice system!
    can you post a straight on shot of the side?
    thanks
    Mar 2005
    Thanks for the compliments.
    Here is a side shot, tried to make it as clean and clear as I could.
    Jan 2005
    Quote Originally Posted by The-Fox View Post
    thanks
    I really like your system, it's very similar to what I'm thinking of building
    I want the A7010 case with just the quad rad and a single GTX 285
    Engineering The Xtreme
    Feb 2007
    MA, USA
    get that tag off of your PCIE cable! very distracting from the beautiful build you have here
    Feb 2009
    BC, Canada
    Nice build
    Never go full retard
    Feb 2008
    Nice use of the Detroit Thermo top and (UN)Designs bracket, I like the way you implemented them.
    Moderator
    Aug 2007
    Back and forth between Florida and Maine
    This build really came out nice - I like your dual colored loop!
    I am Xtreme
    Mar 2007
    Sugar Land, TX
    Came out really nice Fox, but I would remove the coils. It takes away from your work.
    Oct 2007
    sexy
    Asus Maximus II Formula & Q9550 (4.0GHz) w. D-Tek FuZion V2
    Sapphire 4870X2 w. XPSC Waterblock
    8GB OCZ Reaper's HPC DDR2-1066 (5-5-5-10)
    (3) 120GB OCZ Vertex
    (2) 1.5TB Seagate Barracuda 7200.11
    Silverstone Strider ST1000-NV
    Cooler Master Stacker 832
    Thermochill PA120.3 in Series w/ BIP120 w. MCP355
  18. #18
    so there will no gunk what so ever? even in the rads?
    you know those ac ryan rad grills get on of those and put it on there so it will look more sharp!
    i cant find one for 4x120 but you get the idea right?
  19. #19
    Feb 2009
    Virginia Beach
    ive nvr seen anyone make a 4x120 rad grill before....
  20. #20
    Feb 2007
    MA, USA
    IandH makes a stealth grill for 4x120... here: http://shoppts.com/iaqustblgsp.html
  21. #21
    Feb 2009
    Virginia Beach
    looks like im cutting up my A7110 for that girll
  22. #22
    Mar 2005
    Quote Originally Posted by shazza View Post
    Thanks man, it is a decent build, but nothing compared to your monster mega rig
    Quote Originally Posted by SNiiPE_DoGG View Post
    It never caught my eye actually, but I guess you are right.
    Quote Originally Posted by skinnee View Post
    Yahh, they are my Improved D5 twins , I like them a lot.
    Mounting them was a real challenging episode for me
    Quote Originally Posted by Ender17 View Post
    thanks
    Thanks, good luck with your build
    BTW, From looking at the A7010, it uses exactly the same chassis of the G70, so you shouldn't have any problems of space.
    It looks like a more contemporary case than the G70, though still a bit "Lian-Li-oldschool", a killer case
    Quote Originally Posted by theseeker View Post
    Thanks seeker, but I like the coils around the tubes.
    without them, it feels a bit naked, I know it sounds weird
    Quote Originally Posted by iro View Post
    Unfortunately, the iandh quad radgrill were not present at the time of my build, my build is 4 month old.
    I was talking to iandh personally and he was very nice and tried to help me with getting a pre order of his grills but to no avail.
    I would definitely go with his grill if I were you.
  23. #23
    thx for posting that sniipe
    FOX this is a important question i want to ask you about your liquid combination; Will it cause gunk in your blocks since you have anti-corrosion?
  24. #24
    Mar 2005
    I don't think it would cause junk in the loop.
    I put a small amount of Anti Corrosion liquid, about 1/4 a bottle for the big loop (CPU) and half of it to the small loop (GPU).
    So far everything is clear, haven't noticed anything wrong in the loop.
  25. #25
    Jan 2005
    http://www.petrastechshop.com/iaqustblgsp.html
