X5670 B1 @175x24=4.2GHz @1.24v LLC on
Rampage III Extreme Bios 0003
G.skill Eco @1600 (7-7-7-20 1T) @1.4v
EVGA GTX 580 1.5GB
Auzen X-FI Prelude
Seasonic X-650 PSU
Intel X25-E SLC RAID 0
Samsung F3 1TB
Corsair H70 with dual 1600 rpm fan
Corsair 800D
3008WFP A00
Anyone post up the eVGA SSC BIOS? My vanilla BFG OC GTX 285 isn't hitting these clocks, blackscreens in 3D when I try 1650+ shader or 780+ core, though it can hit 3ghz memory happily. I want to try flashing it and see if it improves... think the rumor of voltage adjustments in the eVGA SSC are true. PM me and I'll send you my email if you can please.
Sorry guys, a BIOS won't help you any...There is more to the SC and SSC cards than just a BIOS tweak.
. ss phase . nf11fx compressor . chilly1 evap . r507 . chilly1 condenser . freezepack controller . 965xe 4.63ghz || evga x58 classified || 2x evga gtx 295 || 6gb g.skill 1.6ghz cl8 || corsair ssd x64 || tt 1.2kw w/ 12 awg || win7 x64
I smell ... Vmod!![]()
EVGA GTX 580 1.5GB
Auzen X-FI Prelude
Seasonic X-650 PSU
Samsung F3 1TB
Corsair 800D
3008WFP A00
I had a seriously overclocked 280 pass through my hands a few months ago... it ran a lot hotter than the other 2 (slightly overclocked) 280's I had in for testing at the time and the fan programming was different as standard so I guess the top cards might be factory vmodded ... that would help explain the stupidly high ram clocks some testers are getting with some of the 285's...
No panic guys... MVK will probably have it up in a few hours...
EVGA GTX 580 1.5GB
Auzen X-FI Prelude
Seasonic X-650 PSU
Samsung F3 1TB
Corsair 800D
3008WFP A00
I flashed the BIOS with an SSC one on my BFG OC and it did NOT overclock any better... something may be different hardware-wise, would love to hear more.
EDIT: I'm topping out stable at about 720core/1566shader/1485ram upon testing with either BIOS... after full stability testing. So, I'm really wondering if this is true... may go for an SC or SSC if it is.
Yup. I was just wanting confirmation as well... I just want to hit 1700 shader then I will be a happy bunny!![]()
EVGA GTX 580 1.5GB
Auzen X-FI Prelude
Seasonic X-650 PSU
Samsung F3 1TB
Corsair 800D
3008WFP A00
Jakup = eVGA product manager someone said? Is that correct I assume?
(Not that I expect an answer on this one hehe but...) is the SC the same as the SSC hardware-wise but for the testing and binning?
After looking over the PCB's with high-res newegg pictures, I see there is indeed a different PCB revision for the SSC than the other GTX 285's (which all have the other rev.).... The SC and SSC show the same revision... 4908, whereas the rest all show a 4808 number at the bottom left of the shots.
ssc bios: http://www.megaupload.com/?d=LNJPUY6I
*** use at your own risk ***
btw.. guys whats the ovp on the ssc gtx285 ?
i7-2600K @ 4806Mhz 102.3x47 1.368v LinX stable
MSI P67 GD-80
16Gb Corsair 8-8-8-24 1T 818.2Mhz
MSI GTX560Ti 1005/2250 1.062v
Crucial m4 256Gb SSD
Corsair TX850 | 64bit WIN7 Pro
Custom watercooling
47" 1080p LCD | Onkyo 876/ Polk 5.1 surround
EVGA GTX 580 1.5GB
Auzen X-FI Prelude
Seasonic X-650 PSU
Samsung F3 1TB
Corsair 800D
3008WFP A00
MSI P67 GD-80
Custom watercooling
I'm beginning to wonder if it's my power supply heh... Corsair HX 520w running a GTX 285, Q6600 @ 3.2, 680i motherboard, 4x2GB (8GB) RAM, 5x 120mm fans, 2 hdd's... because it just drops video signal when it crashes, no artifacts or the usual hard lock with the frame frozen on-screen... any thoughts?
4870x2 stock
285 SSC 756/1764/1323-PhysX OFF
CPU running 4ghz
PhysX On
Nice, almost the same (GPU) score as that setup with HD4870 X2, seems these cards fly at shader 1750MHz+.
Intel® Core i7-860 @ 4.1 GHz ¦ Gigabyte GA-P55-UD5 ¦ G.Skill Ripjaws 2x2GB @ DDR3-2340 9-10-9-24 ¦ Gigabyte GTX 460 OC 1GB @ 880/1760/2000 MHz ¦ Corsair HX 750W ¦ ViewSonic VX2268wm 120Hz LCD ¦ CoolerMaster Hyper 212 Plus ¦ Audigy 2 ZS w/ kX Audio drivers ¦ Sony MDR-XB500 ¦ Logitech MX-518 ¦ Win 7 x64 Professional ¦ 500GB, 640GB, 750GB & 2x1.5TB
If all people would share opinions in an objective manner, the world would be a friendlier place
Very nice indeed.... I just wish I knew if it was my PSU or my card holding me back, before I plunk down cash to check for sure which way. Anyone have any thoughts?
Specs:
Corsair HX 520w PSU
GTX 285 1GB
8GB RAM (4x2GB sticks) @ 400 5-5-5 2T 1:1
Core 2 Quad Q6600 @ 3.2ghz (8x400)
2 HDD's
DVDRW
X-Fi XtremeGamer
Five 120mm case fans
eVGA NF68-A1 680i SLI motherboard
