Want to see how it performs before I replace my AS5
~ Little Slice of Heaven ~
Lian Li PC-A05NB w/ Gentle Typhoons
Core i7 860 @ 3gHz w/ Thor's Hammer
eVGA P55 SLI
8GB RAM
Gigabyte 7970
Corsair HX850
OZC Vertex3 SSD 240GB
http://forums.extremeoverclocking.co...d.php?t=227681
Theres a decent lil review of it.
heres some more
http://www.overclockingwiki.org/foru...ead.php?t=2218
http://forums.extremeoverclocking.co...d.php?t=233780
Q9650 L826A965 | 4.0Ghz 1.27v
Gigabyte EP45-UD3P F7 Bios
eVGA GTX 280
CPU= D-Tek FuZion V2 / Laing D5 Basic / XSPC RX-240
Corsair 2x2GB PC2-8500
Corsair 1000HX
AuzenTech X-Fi Prelude | Logitech Z-5500
WD 250GB SE / WD 1TB Green
Antec Nine Hundred
Wow very cool. I may look at it after I get a new rig. Very nice temps
eVGA P55 SLI
8GB RAM
Gigabyte 7970
Corsair HX850
Pfft, I've got a lifetime supply of AS5, until AS5 is proven to kill my children in their sleep I will continue to use it!
Core 2 Duo(Conroe) was based on the Intel Core Duo(Yonah) which was based on the Pentium M(Banias) which was based on the Pentium III(Coppermine).
Core 2 Duo is a Pentium III on meth.
yeah different thermal pastes really i dont see the overrated point, it may lower 2-3C at the best conditions, whats the point of paying that much more for something just to POSSIBLY see the diff. To each his own though, personally I buy 22 Gram syringes of ceramique from bestbyte.net for $4.28 + shipping. And 22grams is anough for prolly 150+ apps
eVGA GTX 280
Corsair 1000HX
Antec Nine Hundred
2-3C from a TIM(!) I'll take it! Really though, are you using that much interface? I ask because, if you are saving it for long periods, how do you do so? I kept mine in the fridge in a ziplock bag for a year. When I used it again it seemed to be dried out. Of course Ceramique is a little funky in that it seems a little dry anyway.
is this the same Liquid Metal substance NASA invented? They use it now in high grade Snow Ski's and is supposed to be really good stuff.
Main Rig
- Intel Core i7 4790K CPU Stock @ 4.4Ghz
- Asus Maximus VI Extreme Motherboard
- 32GB GSKILL Trident X 2400MHZ RAM
- EVGA GTX 980 Superclocked 4GB GDDR5
- Corsair TX850W v2 TX Power Supply 70A 12V Rail
- Swiftech Apex Ultima w/ Apogee Drive II & Dual 120 RAD w/integrated res
- 2X Seagate 333AS 1TB 7,200 32MB HD's in RAID 0
- 2X Samsung 830's 128GB in RAID 0
- Windows 8.1 Pro x64
- Coolermaster HAF-XB
- Dual Asus ProArt PA248Q 24" IPS LED Monitors
- Samsung 46" 5600 Series Smart HDTV
- iPhone 6 Plus 64GB AT&T & Xbox One
UNOFFICIAL Rampage II Extreme Thread
http://www.xtremesystems.org/forums/...d.php?t=159752
http://www.xtremesystems.org/forums/...ad.php?t=72814
One of the few cooling related prducts that actually lived up to the hype (although not problem free).
Didn't Martin test this too at some point?
The temps are probably the best you can get from any TIM. Problem is that you need to sand off the IHS and heatsink once you want to remove the liquid metal again...
This stuff has two nasty features:
1. It becomes solid after a month or so after it's applied on the chip.
2. It stains copper permanently, as if it would soak into the metal itself. Which is exactly what it (gallium) actually does.
Good thing it's totally awesome as a thermal interface material.
You were not supposed to see this.
Oh, one cant really say it would cause a problem when unmounting. The solidifies paste isn't that strong as an adhesive to make the block stuck because of it. Removing the hardened metal off the block and the chip is tedious, though.
It's best to wipe off what you can (maybe with a little acohol to help it) and then lap the rest off of the heatsink and heatspreader. It'll be faster if you already lapped both of them. And as largon already said, the bonding of the HSF to the heatspreader isn't that bad, nothing to worry about here.
Isopropanol doesn't do anything to CLLP.
But there are chemicals that can "sort of" dissolve it.
I have some ancient jewelry polishing paste that just eats through CLLP, it turns into black powder once it comes into contact with the polishing paste. Consequently, the paste also does the same to the metal alloy they use to bond IHS to the core. I think it also causes cancer even if you just look at it.
Anyways, lapping is not necessarily necessary.
Maybe not necessary, but I found it worked pretty well. And lapping an IHS is never a bad thing now is it?
About Isopropanol... well it _felt_ like it was easier to wipe the paste off with the help of it. I know that it does pretty much nothing to the stuff, though.
this is good stuff...tried it...it sorta bonds with copper...a little sandpaper will help removing it....
1. application is easy..its liquid
2. removal is the hardest for any tim
It eats CPU tops!!!
I've got two syringes (makes me sound like a druggie ) of the stuff. It ate the top of my AMD Athlon 4600 X2. You'll have to void your warranty in the end as you'll have to lap the CPU to get the stuff off. Damn good temps thoughs. If you don't give a damn about the CPU go for it. My TRUE was left unharmed so don't worry about it messing your cooling solutions up.
