Hi all,
looking for a 140mm fan with high cfm. So far I found this one
http://www.frozencpu.com/products/79...6c15s775#blank
Any other better than this ?
Hi all,
that 140 has 120mm holes and wont work on 140mm fan mounts.
the only other highspeed one is the delta 140mm, I'm not sure where to find it but there is another on this forum who has it....
I'v seen a 140mm Delta fan that moves 367CFM but its 74DB .
Heres a list of 140mm Delta fans.
38mm
http://www.delta.com.tw/product/cp/d...140&th=38&vol=
50.8mm
http://www.delta.com.tw/product/cp/d...0&th=50.8&vol=
74dB LOL!
That is just insane and will kill your ears...
equivalent to a grass cutter .... lol
damn man that sucks :<
Yate Loon makes some 140mm fans http://www.yateloon.com/detail/38839/38839.html
A few places sell the lower rpm fans but I've only seen the 2800 rpm ones in PSUs, mostly CWT oem eg the Corsair tx750.
the market for 140 fans is low but increasing the 140 that comes with my HAF at the back does push much air it also has 120 fan holes at the back ive decided just to go with a 120 due to the the lack of good 140 available for CFM to DBA ratio
San Ace 140W and 140L are 285ish CFM at 57db or 140ish at 39db, provided they are the x51mm fans.
| Computer | [CPU] Intel E7200 @ 3.9GHz [RAM] 4GB OCZ Platinum
| Hardware | [GFX] ATI HD4850 [MB] Asus P5K
