Anybody know if the gigabyte p55 ud-5 is supported? Can't seem to find the clock generator. Thanks in advance.
Can we get the source code for this? Is it public domain?
[SIGPIC][/SIGPIC]
Post #31
SetFSB programming,the complete code of SetFSB is entirely in Japanese.
http://www13.plala.or.jp/setfsb/SetFSBprogramming.html
Need a Gigabyte latest BIOS?
Z370 AORUS Gaming 7,
GA-Z97X-SOC Force ,Core i7-4790K @ 4.9 GHz
GA-Z87X-UD3H ,Core i7-4770K @ 4.65 GHz
G.Skill F3-2933C12D-8GTXDG @ 3100 (12-15-14-35-CR1) @1.66V
2xSSD Corsair Force GS 128 (RAID 0), WD Caviar Black SATA3 1TB HDD,
Evga GTS 450 SC, Gigabyte Superb 720W
XSPC RayStorm D5 EX240 (Liquid Ultra)
NZXT Phantom 630 Ultra Tower
Win 7 SP1 x64;Win 10 x64
Is there any way to make SetFSB save which clock gen you want to load at startup of the program, so you don't have tp look for it in the list anymore? Should save some time ^^
unfortunately someone was extremely rude to abo-san the creator of the wonderful setfsb application, because of this he doesnt want to continue this project, so this rude user can never get update setfsb again...
thanks abo-san for your great work over the years on this project!
SetFSB will resume soon,but will need activation key to open application....
New beta testing:
http://www13.plala.or.jp/setfsb/down..._3_134_98g.zip
Edit:
Link removed by developer.
SetFSB 2.3.135.99
or
http://www.fileden.com/files/2009/12...2_3_135_99.zip
-Added ICS9LPR600CGLF(ASUS X59SR/F80CR).
-Fixed SiS671 Chipset.
-Changed license to the shareware.
Can't say I can condone this step (making people pay to use a once-free program).
I do understand there is an immense amount of work involved in developing this kind of programs, and I do think donations are important.
Now I am the last guy to about a few bucks, and am already donating left and right if I can, when I can.
It's just that on principle I don't like to be forced. So, I guess I'll have to use another program from now on.
Still, thank you for your long and hard work stasio!
But still can open and use application:
Ah, I figured it wouldn't work any more without a key.
That's fine then
http://www.newegg.com/Product/Produc...82E16813151085
is there any support for a Tyan Thunder n4250QE Quad socket?
id love to be able to OC these
Its not overkill if it works.
Use google? it's ICSLPRS916BGLF on Maximus Extreme.
www.teampclab.pl
MOA 2009 Poland #2, AMD Black Ops 2010, MOA 2011 Poland #1, MOA 2011 EMEA #12
Test bench: empty
Use 914***F or 918***F instead. Last letter is more important than the number, these might work.
Just select any clockgen and try reading the FSB. If it displays the correct value it will also set correctly 90% of the time.
www.teampclab.pl
Test bench: empty
SetFSB v2.3.135.99a
http://www13.plala.or.jp/setfsb/down..._3_135_99a.zip
[SIGPIC][/SIGPIC]
| Intel Core 2 Duo E6600 ES 2.44GHz @ 3.60 GHz | ASUS Maximus Extreme BIOS 1302 Custom | Corsair TWIN3X2048-1800C7DF DDR3 | ATI Radeon HD 2900 XT @ 800/1000 | Creative Audigy 4 Pro | RAID 0 2x Maxtor 6V080E0 80GB 8MB Cache SATA-II | RAID 0 2x WDC WD1200JD-00GBB0 140GB 8MB Cache SATA | LiteOn DVDRW SOHW-1693S | Lian-Li PC-65B | OCZ Powerstream 520W |
SetFSB 2.3.136.100
-Added SLG8SP626V(Acer Ferrari One 200).
