Can you make setfsb for Asus eee (701) laptop and X51L
I try to find spects of clock chips and i didnt find one, i hate open up to get read chip names...
I know it's old, but any chance of support for the DFI LP CFX3200? It uses the ICS 951446 PLL.
Xtreme SUPERCOMPUTER
Nov 1 - Nov 8 Join Now!
Athlon64 3700+ KACAE 0605APAW @ 3455MHz 314x11 1.92v/Vapochill || Core 2 Duo E8500 Q807 @ 6060MHz 638x9.5 1.95v LN2 @ -120'c || Athlon64 FX-55 CABCE 0516WPMW @ 3916MHz 261x15 1.802v/LN2 @ -40c || DFI LP UT CFX3200-DR || DFI LP UT NF4 SLI-DR || DFI LP UT NF4 Ultra D || Sapphire X1950XT || 2x256MB Kingston HyperX BH-5 @ 290MHz 2-2-2-5 3.94v || 2x256MB G.Skill TCCD @ 350MHz 3-4-4-8 3.1v || 2x256MB Kingston HyperX BH-5 @ 294MHz 2-2-2-5 3.94v
Support for the EP45-UD3R? Don't know the clock generator offhand.
~FoxDie~
CM HAF 932
MSI Z68A-GD65
2600k Watercooled @ 4.6 GHz
Powercolor HD6950
4x4GB G.skill Ripjaws X 2133
2x Crucial M4 128GB R0
WD 1TB Black
Any support for Asus P5K Deluxe Wifi AP? My best friend would find it handy for his rig. What clock generator does it use?
..::PC Signature::..
..........................:::::::::::::::::::Name-Tao Te Ching, Chapter 44
E8500 Q820A966 E0 4.012 @1.26V w/Zalman 9500LED
2G PNY XLR8 DDR2-1173@ 1013 4-4-4-10 @2.316V
Visiontek Reference 4870 512M 833/1041 testing w/Zalman VF1000
DFI UT P35 T2R!!!! w/-5/02 BIOS XP Pro 32Bit SP2
Seagate es.2 250G 32M Hitachi Deskstar 750G 32M
Plextor PX-716A TEAC 3.5" Floppy
Thermaltake VA8003BWS w/ TT Toughpower 700 Watt [Seasonic]
Arctic Cooling MX-2 Fluke 179 Digital Multimeter Tripplite Isobar6
Antec Tricool 120MM 78CFM 2X-Silenx 120MM 90CFM Zalman 90MM w/bracket
SetFSB 2.2.123.90
Added ICS9148BF-26(Gigabyte GA-6ZXC), ICS9LPRS133BKLF(MSI X58 Eclipse SLI), ICS9248BF-96(Fujitsu FMV DESKPOWER C5/86WL).
Need a Gigabyte latest BIOS?
Z370 AORUS Gaming 7,
GA-Z97X-SOC Force ,Core i7-4790K @ 4.9 GHz
GA-Z87X-UD3H ,Core i7-4770K @ 4.65 GHz
G.Skill F3-2933C12D-8GTXDG @ 3100 (12-15-14-35-CR1) @1.66V
2xSSD Corsair Force GS 128 (RAID 0), WD Caviar Black SATA3 1TB HDD,
Evga GTS 450 SC, Gigabyte Superb 720W
XSPC RayStorm D5 EX240 (Liquid Ultra)
NZXT Phantom 630 Ultra Tower
Win 7 SP1 x64;Win 10 x64
Working one for a SM X8DA3?
The XS WCG team needs your support.
A good project with good goals.
Come join us,get that warm fuzzy feeling that you've done something good for mankind.
Movieman try this:
It worked on my X8SAX (well at least partially)
I had asked a while back and was told ICS 9LPRS914EKLF. It works for me.
http://www.xtremesystems.org/forums/...postcount=3062
Working For Asus P4B533?? It's Too Old Mobo )
Asus Crosshair IV Formula
AMD FX-8120
ATI HD5750 Silent+ATI HD5770
Kingston 1333 2*2GB
GP1035B
Zalman CNPS 10X Extreme
Sorry For My Great English
SetFSB 2.2.124.91
Added ICS9LPR501SGLF(Toshiba Tecra A9 with the hardware modification).
Supported AMD-790FX Chipset.
Included DFI LP UT 790FX-M2R(ICS9LPRS477BKL), Toshiba Satellite L45-S4687(ICS954310BGLF).
Thanks for this great little program.
I tried the latest version and it works with my SM X8SAX on Win 7 64. I was able to overclock my W3250 to 3.02ghz. The thing is once you set FSB the computer crashes (BSOD) then restarts itself. Once it restarts though you get the higher clocks.
guys I've ran into a odd audio problem while using setFSB with windows 7.. Some of the sound in cut scenes of devil may cry 4 are delayed by a few seconds... everyone sounds like chipmunks in riddick, and the sound cuts out before people finish what they are saying in stalker.
I had none of these problems while running vista. Any ideas? It does it both with my X-FI card and the HDMI sound output of the radeon 4870.
also are there any programs that will let me disable speedstepping in windows? I can't use rightmark anymore :\
Yes unfortunately I experienced the same type of problems with my x-fi. Here's a solution that seems to work (not guaranteed).
-Before you use setFSB go to your task manager and end the following processes:
ctxfibspi.exe
ctxfihlp.exe
ctaudsvc.exe
-Then go to the services tab and stop the following services:
Creative Alchemy AL6 Licensing
Creative Audio Engine Licensing
CTAudSvcService
-now set your FSB
-restart your computer (the services will restart again)
I didn't experience any problems with my sound (don't have the same games though) after I followed these steps.
Please report back if this works for you or not.
SetFSB 2.2.125.92
Added ICS9LPRS471AKL(ECS A770M-A).
Supported AMD-770(RX780) Chipset.
For Unknown Mobo I Thinck Is Foxcann I Cann't Open Case And Look At The Mobo Is Not Mine
Valid CPUZ Link
HP Proliant ML370G5 Server PC
In Corner OF Case Hacked Foxconn
AMD FX-8120
Kingston 1333 2*2GB
GP1035B
