+ Reply to Thread
Results 1 to 6 of 6
Thread: CD drive cover mod
    Aug 2008
    3
    CD drive cover mod
    Hi,
    i want to do the CD drive cover mod but i don't understand how to close the CD drive after i stick the tray cover to the drive bay cover.
    so i need to push it right? so it good or bad?
    its hurts the CD drive?
    did you have any good guide to this mod?
    tanks
    Xtreme Member CodeNinja's Avatar
    Jan 2008
    Port Orange, FL
    0
    It'll be fine if you don't hit it very hard.
    Asus P6T | Corsair H100 | i7 920 @ Stock| 6GB Corsair DDR3 1600Mhz |
    EVGA GTX270 SC 4GB | 4x WD Caviar Black 640GB RAID10 Array | CoolerMaster Centurion 590 |
    Corsair 850HX Modular PSU
    Aug 2008
    3
    any good guide for this mod?
    Nov 2005
    0
    You'll have to look around, but theres a way to solder 2 wire to the cd drive in order to open and close it (via a switch or button.)
    Core i7 930 @ 3.8 1.24v
    Asus P6X58D Premium
    6 gb G.Skill Pi 1600
    Diamond 4870
    Corsair 750HX
    Intel X25-V SSD
    2 x WD 640gb black
    Lian li PC-70
    Asus MS238H LED Monitor
    H2O: Thermochill 120.3, MCP 655 pump, EK Supreme HF (nickel/acetal), San Ace fans
    Nov 2005
    0
    http://www.themodnation-forums.com/v...php?f=33&t=903
    First post is a video, the sound is a little off, but it explains all.
    That's the link I was looking for. It's more difficult and risky, but very rewarding.
    Asus P6X58D Premium
    Diamond 4870
    Corsair 750HX
    Intel X25-V SSD
    2 x WD 640gb black
    Lian li PC-70
+ Reply to Thread
