SteveRo,
I am using the stock pump that came with the Freezone, the way the Pelt chiller works (low volts to six teacs, about 5v each, helps keeps the hot side temps under control), is the SLOWER movement of the water through the chiller and past each pelt which allows for super chilling, and then the delivery of really cool water to the block, if you use a higher flow pump it will not work as well.....this is contrary to a regular water system with high flow, trust me when I say a higher output pump would not work properly. You have to approach these setups with an open mind, they work on a little different principal than regular water....
However, replacing the waterblock to one of better quality will result in about 2/3*c better temps.....
I made sure to mount my radiator so the pump doesn't have to push hard up a long uphill, the top inflow on the DangerGen is the high point, makes for easy filling and bleeding with a new turkey baster (it has got to be 'clean', I have one dedicated for use on my water setup, never used for anything else)......I did think about adding a reservoir for easier filling, haven't ruled it out completely....if you bleed it properly, it works flawlessly as a closed loop...
The pump works very well with the added radiator...like I said in my OP, I wish I had done it sooner.....what I like about the setup as I have it, very compact and efficient, temps rival just about any normal water setup, maybe even a bit better over real long periods of time as I don't have to worry about water warming in high volume systems on long stress runs, it flat lines once it reaches max, and just stays there....
True water enthusiasts may laugh at my cooling setup, but it works rather well I think...
Regarding the pump, you want one that does somewhere between 210 to 235 Liters/hour, this is a little less than 1/2 of what big water users want for flow (500L/hr), and I am using 1/4" ID tubing instead of 3/8" or 1/2" which makes for very easy routing, yes it flies in the face of normal water, but it is very efficient....
laterzzzzz...................
