lets see...
2d seems to be stable, but 3d crashes are pretty reproducable, right?
now which of the components could cause problems...
vista ultimate - excluded cause you tried a fresh install
Q9550 E0 - unlikely
Sapphire 4870x2 - suspicious candidate
Foxconn BlackOps - possibly
G-skill DDR 3 1600 2x2gb RAM - unlikely
PSU - OCZ 850 W - excluded cause you swapped it with another one
HDD - 160 GB seagate 7200 RPM - possibly
most likely its the vga... or the board.
first of all, does this happen at stock speed?
If no, then go back to stock speed and clock your way up bit by bit and try to find the breaking point, and then try to find whats causing it and fix it. the easiest thing id recommend you is to try another vga in your rig, ideally an nvidia vga to make sure its not a driver issue either with the games your playing.
another thing is your getting sound loops or weird sounds when the system hangs right?
it might be a soundcard problem! try the latest soundcard driver and remove the soundcard all together and see if everything works fine then
