+ Reply to Thread
Results 1 to 9 of 9
Thread: 5900 and 5600 heatspreader removal worthwhile?
    Jun 2003
    Finger Lakes of Hell, NY
    0
    I'm contemplating removal of the heatspreader on my 5900 and 5600U gpu's...
    I would be replacing the factory HSF on the XFX 5600U rev2 with a lo-pro socketA setup...
    On the 5900, well, it's a european creative with a BIG copper core coverage only heatsink...
    1. I need to grind the top side flat to make room for ramsinks (stupid creative!)
    2. I don't know if this large copper unit would properly cool without the heat spreader... It definitely is thick and big, but *maybe* a lo-pro socketA hsf would work better?
    I remember ppl pulling teir heat spreaders off of celerons and attaining higher stable clockspeeds... is this the case with these nv3X's or would the performance increase potential be negligible?
    Thanks for any help...
    AMD Phenom II x3 720BE @ x4 | Kingwin XT-1264 Direct Contact Push/Pull Cooler | Asus M4N98TD EVO AM3 NVIDIA nForce 980a SLI | 2x2gb A-Data DDR3-1600 | 2x EVGA GTX 460 Superclock 768mb SLI | Mushkin Enhanced Callisto Deluxe 60gb Sandforce SSD | 2x WD2500KS Caviar Blue SE 16 | Antec Earthwatts EA650 Power Supply | Old 26" 720p/1080i TV | Logitech MX5500/Revolution and MS Sidewinder X5 | Altec Lansing ADA885 THX 4.1/5.1 | Windows 7 Ultimate
    Registered User space-ghost's Avatar
    Sep 2003
    ut2k4 demo ?
    0
    man... that would be pretty wicked but could result in dead vga , any true overclocker would do it >: )
    *btw, welcome to xs forums bro
    Xtreme Addict KnightElite's Avatar
    Jun 2002
    Saskatoon, Saskatchewan
    0
    You might gain a couple ºC. You'll probably gain a lot more if you just remove the heatsink, and replace the TIM with arctic silver, or something else that is better than whatever they ship it with.
    AXP1700+ JIUHB 0302 @ 2400MHz - TEC-Watercooled in The Skyscraper
    ABIT NF7-S , Sapphire Radeon 9500 Pro, 1.5GB XMS3200C2
    XS IRC channel: irc.quakenet.net #xtremesystems
    www.ocfaq.com
    Jun 2003
    0
    So this isn't something that is commonly considered on the newer Flip-Chip designs?
    ... must not offer that big of an advantage... heck, I thought it would...
    I'd like to figure out if these heat spreaders are coated copper or just aluminum... if they're AL, then it's almost obvious that a well fitted Cu unit would certainly do better... or so methinks ...
    Thanks for the welcome...
    Jun 2003
    Ohio
    0
    it doesn't give that much of an advantage, a few C is all.
    It also makes it alot easier to kill the gpu, plus no warranty anymore.
    To me, it seems like a lot of risks for not much gain.
    But, if you're going all out, I geuss it's a step that "needs" to be taken.
    Jun 2003
    0
    bah, I'm turned off on the idea now...
    I'll just lap and be happy... :p
    Xtreme Legend berkut's Avatar
    Feb 2003
    Warsaw, Poland
    0
    in the case of my fx 5800: about 90C less temps:
    www.berkut.neostrada.pl/FXcoolmod
    Jun 2003
    USA
    0
    i removed mine and only gained about 10mhz more..
    but now if you are getting high ide temps it could prevent
    damage to your card..
    Xtreme Member speedstream5621's Avatar
    Sep 2003
    Lake Oswego, Oregon
    0
    Nice mod berkut.
    Ragejg, I'd go for it.
    Samsung SyncMaster 710N
    Thermaltake Purepower 420w
    Athlon 64 3000+ 939 @ 2.42GHz (242x10)(1.55v)
    Gigabyte K8NS Ultra-939
    2x512MB Kingston Value PC3200 (2.5-3-3-10-1T)(2.7v)
    Visiontek X800 XT
    Heatware
+ Reply to Thread
