Results 1 to 11 of 11
Thread: Apogee drive owners, leaking...
    Xtreme Guru
    Dec 2006
    Philly/NJ
    Just got my apogee drive in today from petras, and the damn thing is leaking around the base of the pump where it connects to the LGA775 mounting plate. From what i can gather, the screws being placed only on the one side is causing it to lift on the other side where water can slip past the gasket. Now i made no modifications to screw tighteness when i first got it, when the leak happened i tried tightening the bolts, and it only leaks more, i tried lossening them a little looser and same thing. Not exactly sure what to make of this, has anyone else had this problem? Ill be shooting an email over to gabe but i wanted to get some feedback as well.
    Sep 2006
    Did you have a look inside to make sure the seals are in place? i had one but i never leaked for me.
    intel G860
    asus p8z77-m pro skt1155 bios 1205
    Samsung 2x4b ddr3 1333@1600 8.10.9 1.53v
    MSI gtx560ti twin frozr 1gb
    1x120gb pny prevail elite/1x WD RE4 2TB
    Lg Slimline Dvd/rw sata
    Dell 2405FPW 24"
    Fractal Arc mii
    Xonar DX/Dell soundbar
    Hiper 580watt
    3.9ghz e6300-http://valid.x86-secret.com/show_oc?id=139796
    http://www.techpowerup.com/gallery/1834.html
    Feb 2005
    Charlotte, NC
    Sounds like you may have a broken o ring/gasket. Perhaps it was pinched during assembly and this caused it to fail.
    When I say assembly, Im talking about Swiftech assembly, not you. Might wanna call up Swiffy on this for a replacement seal.
    Regards, Stew.....
    - This message brought to you by Frank Lee E. Snutz
    Xtreme Guru
    Dec 2006
    Philly/NJ
    gabes gona have it replaced for me, they sent me an email this morning, yah i took the whole thing apart after it kept leaking regardless of how i tightened or loosened the screws, the gaskets appeared to be intact just fine, but they were barely up past the plastic that they are seated in, almost as if they shrunk. Not sure how thick the gaskets are supposed to be so its very well possible that they are fine and the plastic mounting bracket is bowed.
    Mr Swiftech
    Dec 2002
    Long Beach, CA
    Quote Originally Posted by Spawne32 View Post
    what surprises me (as mentioned in my email to you), is that these are 100% tested before shipping.. Not sample testing.. 100%..
    CEO Swiftech
    Mar 2006
    Sunny Lizardland
    Quote Originally Posted by gabe View Post
    That's impressive, Gabe.
    Components
    Case: Cooler Master ATCS840/ PSU: Seasonic X750/
    Mobo: Gigabyte GA-z68xp-ud4/ CPU: i5 2500k 4.2-4.8 GHz @ auto/
    VGA: EVGA GTX570 SC 940, 1880, 4500 @ 1.1v (Lucid dGPU)/ Memory: 8 Gb G.Skill DDR3 1866
    Storage: Corsair Force 3 120Gb SSD, Samsung 470 128Gb SSD, WD Scorpio Black 750 (Scythe Quiet Drive)
    OSs: Win7 HP x86_64/ Kubuntu 11.04 x86_64
    Cooling
    CPU: Koolance CPU-370/ GPU: Koolance VID-NX580/ Rads: XSPC RX360, Swiftech MCR-220QP/ Pump: EK-DCP 2.2 (softmount)
    Fans: 3x Noiseblocker m12-S1 @~500-750rpm, 3x Scythe GT 800 @~450-800RPM, Cooler Master 230mm (softmount) @300 RPM
    Tubing: 3/8" x 5/8" Primochill LRT (black)
    Fittings: Koolance compressions and 45/90 degree fittings
    Certified Quiet PC Loony
    Jun 2007
    normally during manufacturing assembly .. the testing is part of it ... each and every product will have to go thru testing to maintain standards and faulty
    it's the bots who does the testing .. sometimes human participate in it if the assembly line requires a human's touch
    occasionally, a random product is picked out and perform rigous testing ... i recall it's part of the ISO requirement
    Mar 2006
    Sunny Lizardland
    Quote Originally Posted by Serpentarius View Post
    Which is what makes 100% testing impressive, especially with a small company like Swiftech.
    Components
    Cooling
    Feb 2005
    Charlotte, NC
    Even the best quality control systems can send out a defect; as can be seen by this thread here.
    Regards, Stew.....
    Xtreme Guru
    Dec 2006
    Philly/NJ
    it never leaked during my pretesting either, only after it was mounted to the board did it start leaking out of the side, only thing i could have done after this was use form-a-gasket to make a better seal along the permiter of the mounting plate but i didnt want to do that without checking with you first for RMA
    Admin
    Feb 2005
    Ann Arbor, MI
    Gabe, any ETA on a 1366 bracket for the Apogee Drive? Maybe a combo 1366 and 775 bracket so you don't have to empty the loop when switching sockets
    I'm a big fan of my Apogee Drive.
