+ Reply to Thread
Results 1 to 7 of 7
Thread: D12SL vs D14SL Yates
    Jun 2008
    0
    I noticed that the 14cm yates are supposedly quieter than the 12cm yates with more airflow can anyone reign in on this.
    They have lower rpm which could explain the quiter dba rating but having the same or greater cfm seems unlikely.
    I googled for reviews of the D14SL but didn't come up with anything.
    Also how are D12BL yates vs. D12SL yates and S flex?
    Was looking toward D12BL yates for horizontal mounting since the SL performed so well in test's here similarly to the S flex's yet much cheaper.
    Engineering The Xtreme SNiiPE_DoGG's Avatar
    Feb 2007
    Beverly MA, USA / Troy NY, USA
    0
    d14's are 140mm fans, thats why they push more air
    140>120 lol
    Jun 2008
    0
    Yeah....
    but
    D12SL-12 47 cfm 28 dba at 1350 rpm
    D14SL-12 47 cfm 25 dba at 1000 rpm
    That's a pretty substantial reduction in rpm while keeping the same cfm....just doesn't seem like it's possible.
    D14SM-12 supposedly has 62 cfm 29 dba at 1400 rpm.....15 cfm from a 2cm increase in size and 50 rpm...just doesn't make sense to me specially when most 14cm fans seem to ahve same cfm as 12cm with worse dba.
    Feb 2007
    0
    615.44 cm2<-- area of 14cm fan blades
    452.16 cm2 <-- area of 12cm fan blades
    12cm is 27% smaller than 140mm
    1350 x .73 = 991 rpm theoretical, 1000 rpm actual to account for systems not being 100% efficient
    Jun 2008
    0
    So yates have good 14cm fans? or do you not know sniipe?
    God that made me feel stupid which such simple math and me having a mth final tommorow
    Feb 2007
    0
    I havent used them, there really arent a whole lot of options though...
    May 2006
    UK
    0
    I have L/M 140mm YL fans, very little noise difference between the two fans IMO and they are both very quiet fans, currently using the 140mm M as my rear exhaust.
    To me the 120mm L is more audible than either 140mm L/M
    I have 7 real 120mm Ls so they aren't duff or anything, still quiet though, I have 3 in my bro's CM690 plus a 140mm L, overall just a gentle hum.
    i5-750 w/ Thermalright Ultra120X
    Coolermaster HAF-932
    MSI GD65
    2x2GB G.skill Cas7 1600MHz
    Sapphire HD6870
    Western Digital 640GB.AAKS
    2x Samsung F1 1TB
    2x Samsung SLC 64GB SSD
    Pioneer DVR-212BK
    Corsair HX620W
    Creative X-Fi Xtreme Music (dead, using onboard -.-)
    LG W2286L
+ Reply to Thread
