So far we've got some 3D renders of the accelerating sections. Here be they:
This one is a view from the end, looking at the bore. You can see the projectile in the middle:
The next one is an oblique view of one end. You can see the bullet ready to enter the gun. The top and bottom part is 3/4" thick plexiglass, the brownish coloured part is the rails, which are 5/8" thick. The bullet itself is .50 Cal. The bolts along the side are what will hold it all together. They are Grade 5, 3/8" diameter bolts. They are spaced every two inches.
The last one is the entire "rail" portion of the gun. The whole thing is 32" long, 2 1/4" thick, and 3" wide.
For power, I am getting 110 2400 uF, 400V, 450Vmax electrolytic capacitors. Total energy of the power supply when fully charged should be ~20kJ.
Still working out the details, but suffice to say that if I fire a 10g bullet, and the railgun is only 5% efficient, it will go at ~Mach 1.5 I should be able to get more efficiency than that (or so I hope).
There will also be a compressed air injection system (hopefully injection speeds will be upwards of 100 m/s).
