+ Reply to Thread
Results 1 to 16 of 16
Thread: Best mobo for Q6600 ocing?
    Aug 2006
    0
    Question Best mobo for Q6600 ocing?
    Hi! First of all... sorry for my bad english!
    Second... to me!
    Third... the question: what is the best MB for ocing the Q6600?
    I have one G0, and I want to oc it.
    First... surfing the net I've found that the P45 is the best for that I want... Is it true?
    Well... I have seen these mobos:
    From Asus: P5Q Deluxe "and" Maximus II Formula (this is too expensive, I prefer P5Q Deluxe)
    From DFI: Lanparty DK P45-T2RS / Plus and UT P45-T2RS (what is the difference between the T2RS and the T2RS Plus? only that the Plus has 2 more SATA? ; and what is the diference between DK and UT, a part of the price )
    I only put the mobos with DDR2... would you use DDR2 or mobo with DDR3 support (like P5Q3-Deluxe or T3RS / Plus)?
    Thx for all!
    ByE!
    PD: I will use Zalman 9700LED for the CPU
    I am Xtreme Leeghoofd's Avatar
    Sep 2006
    19
    P5Q Dlx and Gigabyte UD3P will give you amasing value for money... I hope you can reach 3.6-3.8Ghz. It for sure will not be one of these mobo's holding ya back, but more the CPU (FSB wall, heat output,...) and ya cooler...
    I've got nothing against DFI boards but they are very very complex in the bios department... if you are not a bios engineer you can get very lost in it, though for a tweaker it's a heaven sent
    Question : Why do some overclockers switch into d*ckmode when money is involved
    Remark : They call me Pro Asus Saaya yupp, I agree
    Oct 2007
    0
    God, i hate those zalman coolers...
    a P45 mobo is probably recommended, I stick to Asus myself, but each to their own, there is no 110% right answer to that anyway
    Xtreme Cruncher HuffPCair's Avatar
    Sep 2008
    Kansas City, Missouri
    1
    I would stay with DDR2 but that is me I have not yet wanted to really go to DDR3 yet. I would go with the Deluxe, that is just me I have been looking into getting one soon to get rid of my crap board I have now.
    But really it is up to you there is no right answer all these boards will work like they said above its your CPU that will be stopping you. Good luck though
    ~ Little Slice of Heaven ~
    Lian Li PC-A05NB w/ Gentle Typhoons
    Core i7 860 @ 3gHz w/ Thor's Hammer
    eVGA P55 SLI
    8GB RAM
    Gigabyte 7970
    Corsair HX850
    OZC Vertex3 SSD 240GB
    Xtreme Addict ReverendMaynard's Avatar
    Nov 2007
    Toronto, Canada
    0
    ASUS P5K Premium Black Pearl Edition.
    GB 790XTA UD4
    GSkill Pi Black 2000 Cas9
    ASUS 4870
    Enermax Revolution 1050+
    http://www.heatware.com/eval.php?id=67661
    Xtreme Member TheGanG's Avatar
    May 2008
    0
    World record: 5133 MHz
    If u have an average chip, u don't need a good/expensive mobo, if u have a nice chip, P45 will be fine. NVidia 780i is another good choice for Q6600.
    Intel DP55KG-Core i5-750-Kingston Hyperx DDR3 1800MHz-EVGA 9800GX2SC-High Power HPC 1000 G14C 1000W-HP W2448HC HDMI
    Intel DP55KG-Core i5-750-Kingston Hyperx DDR3 1800MHz-Sparkle 8800GTX-SilverStone ST1000NV 1000W-Samsung T260HD
    Xtreme Member VOID WARRANTY's Avatar
    Oct 2008
    Florida..Tampa and St Petersburg
    0
    Ep45-ud3p
    i7 920 4.2ghz..6gb 1600mhz cas 7 memory..Windows 7 Ultimate Edition..Windows XP..650 watt PS..Water..3DFX Voodoo 3
    Dec 2006
    0
    Asus p5q pro or asus p5q-e.
    Jun 2008
    0
    My P5E hit 4.0GHz stable and could bench at 4.1GHz.
    I just got my UD3P so i'm still testing it.
    Oct 2005
    0
    Many like the Gigabyte EP45-UD3P, apparently getting good results from doubling the copper in the motherboard itself with a positive impact on heat management and probably EMI. The Maximus II Formula adds features and style...not important if price is an issue. It 50% more expensive than the Gigabyte. The DFI UT has a digital PWM Buck converter...that converts 12v to 1.2-1.5v for the CPU. It is faster responding, more stable and noise free than the analog setups. For example, I believe the chokes (inside those little square covers) have a 20% production tolerance. The DK just has BIOS features...If going DFI I would pick the UT.
    Note, if new to this browse around on this and other forums for motherboard specific threads. See which ones have active posters being successful doing what you want. It implies success is possible and help may be available.
    Also, remember your power supply and head sink/fan are part of the equation. Of the boards mentioned, only the Maximus II Formula has a way to add water cooling to the northbridge easily...so case ventilation is also important.
    Nov 2007
    0
    well if you're a noob to oc, better stay clear of the dfi cos you gotta expect to do lotsa tweaking to get everything up and running. It won't be a simple matter of just changing some settings and seeing your cpu fly at 4ghz or whatever
    Aug 2006
    0
    I'm not a noob ocing!
    I've started in this world with the Athlon XP and the Athlon XP-Mobile, do you remember these cpu's?
    But... I've busy one-two years and I can't stay at day with actual OC.
    This is because I've asked to you what MB has to buy now to OC well.
    P5Q-Deluxe... DK P45-T2RS or UT P45-T2RS... arghhhhhhhh
    Thx!
    ByE!
    Registered User Ledge's Avatar
    Sep 2007
    Monee IL.
    0
    Yes the P45 is what your looking for and the Gigabyte EP45-UD3P is the one you want.
    It's a great over clocking board for quads and dual cores.
    GIGABYTE GA-EP45-UD3P
    E8400@4.25Ghz
    4x1Gb Ballistix PC-6400@5-5-5-15 1000Mhz
    8800GTS 640Mb
    WD 74Gb Raptor
    Maxtor 250Gb
    Vigoor Monsoon II TEC disconnected
    Sceptre 20.1"
    Avermedia M780 PCI-Ex1
    Vista 64Bit HP
    May 2008
    0
    If he has a good chip, yeah...
    Xtreme Member rockfella's Avatar
    Jan 2008
    0
    OP my Q6600 does 3.91 (unstable though) with a crappy abit IP35-E mobo.
    Gigabyte EP45UD3P and R and doing very good these days. Get EP45-UD3P if you want crossfire or the R if u dont want CF.
    AMD Phenom II 560-Gigabyte GA78LMT USB3-Corsair Vengeance 4GB DDR3-ASUS Xonar DX-1250GB-DELL SP2208WFP-VX450-Corsair Carbide 400R
    Mar 2005
    NYC (LAMF)
    0
    the t2rs plus adds 2 sata ports and replaces the t2rs, assume that dfi made a few fixes. the difference between dk and ut is the ut board has digital pwm and better cooling, more features, slightly better bundle. the dk boards are fine for 65nm quads.
    I7 920 @ 4400 TRUE......Q9550 @ 4000
    evga X58.....................DFI LP UT P45 T2R
    Patriot ddr3 1600..........Super Talent 4gb
    HD4890 CF...................9800GX2
    Zalman 1KW.................Corsair 750
    Lian LI V1000B Plus 2.....Lian LI A05b
    Boot Drives are 80gb Velociraptors
    all os vista64 ultimate
+ Reply to Thread
