Can I combine 8800GTX card with 260 nividia card together?
will they run ?
will they run ?
they will run independant and u could use the 8800 for dedicated PPU but i fail to see the point unless u are running 4 monitors
5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
Well, it depends what you want to use them for "together". I don't think you can SLI them, but you can (as said above) use one of them as a dedicated PPU, or just for a multiple-monitor setup. For either one you'd at least want to have enough bandwidth in both PCI slots, and I can't say I recommend using one as a dedicated PPU.
You have to run the same Nvidia driver for both cards.
SLI = No way
Multi monitor = Joy
ASUS A8N32, FX-57, 6800GT's(SLI)
PCP&C 1kw, Raptors, DDR600
As an extention to this, I have recently aquired a TRI-SLI Mobo.. .An Asus P5N32-E SLI
Now, I have finished with my twiddling about experiments with SLI, but 3?
Anyway, I have got a pair of 8800 Ultra OC Cards ( Matching of course ) anmd right now they are in seperate boxes, but can I put them together in the Asus along with somethign else and use the somehtign else for a physics card perhaps?
What about a dedicated Phyasics card?
Is it actually worth bothering with, with a pair of 800Ultras?
Other nVidia cards I have are a Zotac 8800 GT ( 512MB ) and a Point of View 8800GTS ( 320MB )
Or would I simplly be wasting my time even bothering?
Is there any bench tests that I could run to compare them?
Sorry to butt-in, but thanks.
