Anyone else notice a high pitched squealing sound coming from someplace around the CPU socket when the system is under load? My system is very quiet (water cooled with low-rpm fans) so it becomes very noticeable. With the case open, just try to put your ear over the CPU socket while starting and stopping Prime95 or IntelBurnTest. I'm using a Q9550 @ 4Ghz but noticed this noise even running stock speed and voltages.
Guess it's caused by the issue discsussed in this article:
http://theovalich.wordpress.com/2008...280-squealing/
Just wondering if all EP45-UD3P boards are affected or only a few. I still have time to exchange this board if this is a rare problem.
Thanks.
i7 920 4.2ghz..6gb 1600mhz cas 7 memory..Windows 7 Ultimate Edition..Windows XP..650 watt PS..Water..3DFX Voodoo 3
