The XS WCG team needs your support.
A good project with good goals.
Come join us,get that warm fuzzy feeling that you've done something good for mankind.
There is a pinhole leak somewhere in the 1st stage. It doesn't lose any discernible amount of gas but it slowly loses vacuum. Had it vacuuming for 2 hours, closed the valves and shut off the pump and it slowly started to pressurize, not good. Tearing all the insulation apart now.
Who's excited? I'm excited. Glad to see this coming around.
i have also gotten back all my stuff!
thanks Nol.
Lind: Dual Gainestown 3.07
Its my fault.. and no im not sorry about it either.[12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
Found some oil inside the HX insulation near the bottom, looks like that is where the leak is. Problem is nothing is bubbling up with a toothbrush and soap. It looks like it'll fit in my bathtub so I'm going to dunk the unit after I remove the fan shroud/fan motor and try to pinpoint this leak. There are only 3 joints I suspect but they all look solid *grumble*
It's unfortunate about Adam's troubles but I can't agree more with this evaluation of Chris being one of the good guys. Add me to that excited list.This pleases me, wtg nol! When he first mentioned this leak way back, I knew it was gonna be one of those tough to track ones. I guess they never got to the point of rebrazing joints. Thanks once again Gomeler
dx58so
w3520@4100
4x1gb corsair ddr3-1333
gtx 295
TR ultra-x, 2 scythe ultrakaze push/pull
xclio stablepower 1000
vista ultimate
[SIGPIC][/SIGPIC]
would you crunch if you thought it would save her life?
maybe it will!
My hats off to ya Chris. Your taking on a big job!! Hope you didn't bite off more than you want to chew.
Chris I told you at GOOC about how I feel with reguards to helpping as many people out as you have, and are doing now.
But... Thanks again, You Rock !
Dude... no way. So yesterday afternoon I dunked the cascade into big tub of water and let it sit after knocking off all the bubbles from the piping. I went out to dinner, came back, and saw nothing. Too tired to remove the cascade, I went to bed. I woke up, started my day, looked at the cascade and it looked all normal. 20 minutes ago I heard a bubbling noise. Whatever the leak was, it took 24 hours under water for it to show but now it is bubbling away like a gaping hole. Looks like the hole is where the suction exits from the HX with the 1/2" copper to steel connection. Draining the tub and working on fixing this now. Glad I found the leak this way, the next step was to tear it apart and test the hx and condenser separately.
that made me laugh
way to get to the hart of the problem fast
i want to see the images of this
1. The first rule of Bench Club is, you do not talk about Bench Club
2. The second rule of Bench Club is, you do not talk about Bench Club
3. If someone says stop, goes limp, taps out, the the benching is over
4. No bummers in the batcave, apart from unkie dave
5. One Bench at a time
6. No air, no water
7. Benching will go on as long as they have to
8. If this is your first night at Bench Club, you have to Bench
I don't know why I laughed harder,a 3mm gap or a cascade in a bath Tub leak tested.
Buy a inspection mirror,it's a must to be sure the braze flowed completly around the joint. Especially in tight spots or where you have to be carful with the flame heat. After every braze ,out comes the mirror & mini mag light.
Even pin holes are easy to see if you look.
The Laws of Thermodynamics say:
Zeroth Law: "You must play the game."
First Law: "You can't win."
Second Law: "You can't break even."
Third Law: "You can't quit the game."
Do you wanna Play Thermodynamics ???????? I forgot "you must"
Sent Ron the photos, he's going to upload/host until XS gets it's act straight. It was the strangest leak though, I swear I looked over every braze all the way around and never saw this gap, pretty certain whoever did the brazing did the same thing and just saw a ring of filler metal and oxidized metal. I suspect the water dissolved the oxides enough that the internal pressure blew out the plug. It sure made a nice bubbling racket when it burst. Tomorrow morning I'll braze everything up, I think it'll have dried out sufficiently and start vacuum testing it again. I'll make sure to take a macro shot of the gap tomorrow.
Cheerleading section rolls in...
Here's the pictures I've snapped so far. I didn't take many as well.. it is just a repair
And yes, I forgot to put a cap on the suction valve on the 1st stage when dunking it but it should be fine *doh* Compressor oxidized a little, so a little sandpaper and spray paint are in need.
nice find there
mentally confused and prone to wandering
dx58so
w3520@4100
gtx 295
vista ultimate
[SIGPIC][/SIGPIC]
maybe it will!
First stage fixed, I think. it is still a little warm from the brazing so waiting for it to drop down to ambient before bubble testing again. Gave it a little extra silver as it looked like two parts of this joint weren't sealed. Will have pictures uploaded later tonight after I leaktest to make sure everything is fine.
edit: Hooked up the vacuum pump and it is still losing vacuum although at a fraction of the speed it was prior. Might have to chop it up still and leak test each component.
I have leak tested a unit for 2+ weeks at 310psig and it still rose while in a vacuum. WHere is your vacuum gauge? it could be the different levels of vacuum within a system equilizing
*doh* Thanks Teyber, you just joggled my mind. Perhaps the decrease in vacuum I'm seeing is refrigerant in the oil coming out? Unlike most builds when the oil is fresh and clean, this oil is laden with refrigerant. Anyone else have any thoughts?
Guess I'll pressurize the system and see if I lose any gas.
idk, im more thinking out loud but if your vacuum guage is somewhat close to the vacuum pump, the vacuum is going to be a LOT more sever near the vacuum gauge then in the farthest point in a system isn't it? and like you said, won't bits of water be coming out of the oil when its in that big of a vacuum?
