Ah, thanks muchly.
I had thought there were <10 applicants so only half who applied must have posted.
Eagerly awaiting the news
Ah, thanks muchly.
I am reviewing a unit and should have it in a few days.
i5 3570K@ 4.8GHz 1.32v, 32GB Gskill 1866, Gigabyte g1 sniper m3
HD7970@1125/1575 stock voltage
1TB F1+2*128GB Crucial M4
Silverstone 450w, no case
2560*1440@120Hz overclocked catleap
Steelseries G6v2+5600dpi modded logitech trackball
I have one here now. Just need to load it up with some 4gig RAM chips.
who won?
[SIZE="1"]Gateway MT6707 Notebook
Intel Pentium Dual Core T2060 1.6 GHz
Memory 2048 MB 533MHz DDR2 SDRAM
Intel Graphics Media Accelerator 950
224 MB shared video memory
High definition audio 2 channel
160 GB HD
8X Multi-format dual layer optical drive
802.11g wireless LAN
4 USB 2.0 ports
If you have done a transaction with me, please fill out my heatware. http://www.heatware.com/eval.php?id=64039
If you believe in Jesus Christ and are 100% proud of it, then put this in your sig
I don't think anyone has won yet. Awaiting my unit
"Prowler"
X570 Tomahawk | R7 3700X | 2x16GB Klevv BoltX @ 3600MHz CL18 | Powercolor 6800XT Red Devil | Xonar DX 7.1 | 2TB Barracuda | 256GB & 512GB Asgard NVMe drives | 2x DVD & Blu-Ray opticals | EVGA Supernova 1000w G2
Cooling:
6x 140mm LED fans, 1x 200mm LED fan | Modified CoolerMaster Masterliquid 240
Asrock Z77 thread! | Asrock Z77 Extreme6 Review | Asrock P67 Extreme4 Review | Asrock P67 Extreme4/6 Pro3 thread | Asrock Z68 Extreme4 thread | Asrock Z68 Extreme4 Review | Asrock Z68 Gen3 Thread | 8GB G-Skill review | TK 2.ZERO homepage | P5Q series mBIOS thread
Modded X570 Aorus UEFIs
I guess the 10 reviewers have been chosen then.
160 GB HD
4 USB 2.0 ports
The unit for review, as mentioned in the first post
but i thought they haven't chosen anyone yet?
160 GB HD
4 USB 2.0 ports
Perhaps Jason should have made a post in this thread mentioning that the 10 people had been chosen.
It appears the 10 participants have already been chosen, and whoever writes the best review will also get an additional 9010 RAM Disk as well as an ANS-9050 5 bay RAID enclosure. All participants will be given a free sample of ANS-9010 for review ($399 value)
All participants who posted and submitted reviews will receive an APC-2200 ($45 value) Multi Interface Bridge
Winner
Winner will receive an additional unit of 9010 RAM Disk (YAY for higher RAID setup)
Winner will also receive an external 5-bay hardware RAID(0, 1, 5) sub-system (ANS-9050) ($750 value).
My unit arrived a few minutes ago, can't wait to play with it in the morning
Damn me. I just read about this today! Dec 29th. I so would have participated, and then I could have done a 4xRAID0 on the thing for testing. O well. No reviews for me .
-Josh
i guess i wasnt one of those 10
160 GB HD
4 USB 2.0 ports
Yes, I think we need a few more days considering some of us had delays in receiving them.
I loaded mine up with 8x2gb sticks and did a buch of synthetic tests, but no real-world stuff yet.
4GB was way too costly, I was looking at them also. Would need to work for a memory manufacturer to make it a viable option which unfortunately puts a dent into what can be done with the ACARD.
Indeed, I haven't received my unit yet (tho I'm not in the US, so not entirely unexpected).
Just completed my review and posted here
http://www.411overkill.com/forum/php...hp?f=83&t=4397
Others on this board better understand all the tech behind these units much better than me and I love to see all the different stats. Josh did a great job of doing this here on XS. Thanks so much Josh you did really great work there !
Much of that information is over my head tho, or used for a different purpose that I would use this product for, which would be Gaming, Productive Apps like Photoshop etc. With only one user high IOP's are not that important to me, but Access Time and Bandwidth are. This drive provides both !
The date was pushed back in case anyone didn't get the email.
Good thing too, because I've only done synthetic benchmarks so far, still need to do some real world testing
i5 660 / Asrock P55M Pro / Ripjaws / GTS250
Oh I want to... I only had 16gb RAM and I wanted to run a OS on it so I needed the full amount of RAM for that. If I was running the full amount of RAM I would do that, but that was pretty costly.
I would rather run 2 drives with 16gb installed in each, then RAID them together for a full 32gb in RAID 0.
You can install 16Gb of DDR2 on one 9010, set the jumper to dual mode, and you will have 2x 8Gb "disks". When RAID0'd you will get the same capacity you have now (16Gb) but double the performance.
If you get a 2nd unit, you repeat the same and end up with one 32Gb disk, comprised of 4x 8Gb drives in RAID0 and 700Mb/sec speed
