http://www.auzentech.com/site/company/press.php
http://www.auzentech.com/site/products/x-fi_forte.php
Clearly states *native* PCI Express, so no bridge chip or Floppy power requirement
Gigabyte EP45-DQ6 - rev 1.0, F13a bios | Intel Q9450 Yorkfield 413x8=3.3GHz | OCZ ProXStream 1000W PSU | Azuen X-Fi Prelude 64MB X-RAM| WD VelociRaptor 74HLFS-01G6U0 16MB cache 74GB - 2 drive RAID 0 64k stripe | ASUS 9800GT Ultimate 512MB RAM (128 SP!!) | G.SKILL PC2-8800 4GB kit @ 1100MHz | OCZ ATV Turbo 4GB USB flash | Scythe Ninja Copper + Scythe 120mm fan | BenQ M2400HD 24" 16:9 LCD | Plextor 716SA 0308; firmware 1.11 | Microsoft Wireless Entertainment Desktop 8000 | Netgear RangeMax DG834PN 108mbps; firmware 1.03.39 + HAWKING HWUG1 108mbps USB dongle | Digital Doc 5+ | 7 CoolerMaster 80mm blue LED fans | Aopen H700A tower case | Vista Home Premium - 32bit, SP1
Not all solid capacitors this time, a combo it seems....what the hell are those green capacitors??
Oh!..a sale on the Auzen X-Tension DIN: http://www.auzentech.com/site/produc...ension_din.php
There's another thread already for this card.
http://www.xtremesystems.org/forums/...d.php?t=209645
Coding 24/7... Limited forums/PMs time.
-Justice isn't blind, Justice is ashamed.
Many thanks to: Sue Wu, Yiwen Lin, Steven Kuo, Crystal Chen, Vivian Lien, Joe Chan, Sascha Krohn, Joe James, Dan Snyder, Amy Deng, Jack Peterson, Hank Peng, Mafalda Cogliani, Olivia Lee, Marta Piccoli, Mike Clements, Alex Ruedinger, Oliver Baltuch, Korinna Dieck, Steffen Eisentein, Francois Piednoel, Tanja Markovic, Cyril Pelupessy (R.I.P. ), Juan J. Guerrero
That green shiny thing looks hazardous
RADIOACTIVE CAPACITORS! Ionizing radiation is the new upscaling
The height of the card bracket, is this card for HTPC crowd ? Or will it come with a bracket suited with a standard ATX case ?
Check the other thread.
It's full of information.
looks good. is this in competition with Xonar DX?
so no need to recap?
not recap worthy.. unless you got no other choice lol
is this low profile?!
Cpu: Intel Core i7 920 @ 3.9 ghz (cooled w/ Apogee GTZ)
Mobo: Gigabyte EX58 UD5
Ram: G.SKill 3x1 GB DDR3 1600
GPU: GTX 280
PSU: E Power 1000 Watt
Yes it is.
ahh.. well that sucks... not that it matters my computers on the gigabyte box anyway.. lol
i'm in the field for a soundcard but not too sure what to grab
any suggestions?
GPU: GTX 280
Open up a thread in the appropriate section and tell us what you're going to do with your PC/sound card.
If you need it for gaming you need the A card.
If you're more interested in studio-type recordings you're better off with the B card, etc.
Supply the other members with information regarding your requirements, your limitations ( perhaps only having a PCI-Express x1 slot available, etc ), your intentions, etc to get some good advice by the fellas
To those wondering the card will be bundled with both normal and low profile brackets so you can install in most cases. You could recap the card if you want and add a better opamp but the stock caps don't look to bad as it is. Will have to run the card through it paces and see what it is actually capable of.
Looks good. I like it.
Current setup: http://www.xtremesystems.org/forums/...postcount=1843
Wonder how much better or if any at all than the x-fi titanium.
IIRC, The Forte is said to have a 120dB DAC so it should easily surpass the Titanium.
You can also pop in a higher quality opamp and further improve the sound quality. The Forte has yet to be tested in the realworld using analyzer software..etc.
