I haven't seen a thread based on the X58 MSI platinum motherboard so I thought I'd post my results. Now a big * to the fact I am ram limited in my choice now due to only having 2x2gb of Mushkin DDR3 1600mhz rated, I forget the model #.
I can overclock the combo on STOCK aircooling to 3.7ghz. Anything past that is not possible due to heat, as fully loaded in prime at 3.7ghz at 1.325v is 90C. I've upped the vQPI to +0.2v. PLL to 1.82v. Ram voltage to 1.65v. NB and other voltages I've removed from auto and placed at the lowest available setting. At auto the cpu voltage was 1.5v when the system was oc'd :O.
Now the one issue I'm having past cooling, is that I cannot run anything over 1100mhz on the memory. This memory has run 1800mhz for me at 8-8-7 on my P5K3 deluxe. Not sure what is wrong. It won't run 1333mhz even at bus clock of 100. There is no adjustment I can tell to alter NB multiplier.
Overall I like the board, and for the $ it seems to be a very decent overclocker and very stable for me. I think the Asus is probably a better "last drop" overclocker, but for the average user it seems very good. Then again, I may not know the correct setting to change, or we may be a bios setting away from achieving Asus like clocks
