Results 1 to 24 of 24
Thread: Msi X58 Platinum will not POST
    I am Xtreme
    Oct 2007
    Down South USA
    I ordered this board last week and installed all the components and it would not POST. So I RMA'd the board. I received the new board yesterday and same thing. The board was coming on for about 20sec. then shutting down. I then took out the cmos battery for 10 min. and now the system comes on and will not POST. It will stay on as long as I leave it on but no POST. I thought maybe it was my PSU mushkin enhanced 550 watt but I put it back into my OC'ed q6600 system and it worked perfectly, I also used my daughters antec 550 wat psu and same problem. I have that system OC'ed to 3.6 ghz. My components are as follows:
    MSI x58 Platinum
    i7 920 cpu
    2 gig ocz reaper ram (1333 version)
    Mushkin 550 enhanced PSU
    8800gts GPU
    DD i7 waterblock
    dtek db-1 pump
    Any help will be greatly appreciated. By the way I am more of an enthusiast than a gamer.
    PS I am not getting any beep codes. I took my system out of my MM H2G0 and put it into my antec nine hundred (has a speaker) to test for beep codes and I do not get any codes. Is there any possibility my cpu is dead?
    i7 920 oc'd 4.25ghz
    Asus P6T mobo
    12 gig Patriot ddr3 1333 oc'd 1611 ghz
    EVGA GTX 260 x2 sli
    EK Supreme cpu block
    MCP655 pump
    TC 120.3 rad
    Swiftech MCR-220
    Swiftech micro res 2
    MM U2-UFO CYO
    PCP Cooling 750W Silencer
    Windows 7 RC
    I am Xtreme
    Oct 2007
    Down South USA
    I spoke with MSI and all they said was rma the board. I guess I will rma the board,cpu and ram back to newegg.
    i7 920 oc'd 4.25ghz
    Asus P6T mobo
    EVGA GTX 260 x2 sli
    MCP655 pump
    TC 120.3 rad
    Swiftech MCR-220
    MM U2-UFO CYO
    Windows 7 RC
    Xtreme Mentor
    May 2008
    Yeah, sounds like a bad board. Thats how my P7N went out. MSI then sent me a board with no heatsinks. Their quality control is horriffic. Ill never buy another MSI product.
    I am Xtreme
    Oct 2007
    Down South USA
    I decided to only rma the cpu and ram. I just got the board back yesterday from rma. It was told to me the x58 platinum has a problem with ram from over at hardocp. When I get the new ram and cpu and it does not fix the problem I will rma for a refund and get the asus board.
    i7 920 oc'd 4.25ghz
    Asus P6T mobo
    EVGA GTX 260 x2 sli
    MCP655 pump
    TC 120.3 rad
    Swiftech MCR-220
    MM U2-UFO CYO
    Windows 7 RC
    Sep 2007
    Vietnam Overclocker Zone
    Put RAM to black slot.
    Mar 2005
    Bay Area, CA
    that reaper needs more than 1.65 vdimm, eh? that might be the issue right there..
    Gigabyte x58 UD5 / core i7 920 @ 3.8 / 6G ddr3 / 100G Patriot Inferno + 500G WD / gtx470 SLI watercooled / x-fi / 1KW enermax / 5760x1080 surround
    Gigabyte z68x-ud3-b3 / core i5 2400 @ 3.6 / 8G ddr3 / 120G Intel 510 + 120G Adata S599 + 2x 1T WD blue / Zotac gt430 / x-fi / 500w ocz / 1920x1200
    DFI pro875B / pressy 2.8 / 2g corsair xms pro / 6800gt agp / 150g raptor x / 500w ultra x-connect / lots of UV lighting / smiles
    MSI K7N2 Delta-L / Athlon xp2600+ / 1G ocz platinum / chaintech TNT2 / 2x Diamond Monster 3D II SLI / Audigy / more smiles
    I am Xtreme
    Oct 2007
    Down South USA
    I used all the slots it did not work. I think it was the reaper ram. It required more than the 1.65v. I rma'd the ram along with the cpu. I tried everything to get the system to POST. I changed psu's moved ram from slot to slot, disassembled reassembled 4 times and nothing. The editor over at ocp told me he had problems with ram on that board.Hence the delay in a review for the platinum.
    i7 920 oc'd 4.25ghz
    Asus P6T mobo
    EVGA GTX 260 x2 sli
    MCP655 pump
    TC 120.3 rad
    Swiftech MCR-220
    MM U2-UFO CYO
    Windows 7 RC
    Sep 2007
    yep, My X58 Platinum can't work with 2x1GB Adata 1600X.
    RAM setup
    Due to the memory settings for X58 is kind of different as usual
    Attached please find the memory setup directions for reference
    The suggestion settings would be A0B0C0A1B1C1 when you have different numbers of memory
    I am Xtreme
    Oct 2007
    Down South USA
    If you do not mind what ram are you using now? Newegg is going to issue me a refund on the ram so I can purchase a different type. I am not trying to spend a fortune on ram. What is a good reasonable priced ram for the x58 platinum.
    i7 920 oc'd 4.25ghz
    Asus P6T mobo
    EVGA GTX 260 x2 sli
    MCP655 pump
    TC 120.3 rad
    Swiftech MCR-220
    MM U2-UFO CYO
    Windows 7 RC
    Mar 2005
    Bay Area, CA
    I would get G.Skill 9-9-9-24 for it.. either 1333 or 1600.. (that's what I have on the way) It's got a low vdimm requirement, like 1.5v or 1.6v and I think this board is a little sensitive to ddr3 which needs higher vdimm.
    Banned
    May 2008
    vermont, yes i like women
    wait you are using 2X1GB of ddr3?? thats why this board wont post m8, you NEED 3X1GB for it to post I'm surprised msi did not catch that but read their online PDF manual it says it right in there.
    Oct 2002
    IL
    you don't need 3 dimms to post. I have 2x2gb in mine and it posts. In the manual you are asked to use the 2 closest black slots to the cpu for 2 dimms.
    it's never fast enough!
    May 2007
    Ubatuba, Brazil.
    I got this results with MSI X58 PLATINUM, of course my memories are OCZ PLATINUM 1600MHz with 1.9V and I used cooler box.
    http://valid.canardpc.com/show_oc.php?id=454533
    Sorry for my bad english.
    Sep 2007
    MSI X58 Platinum can run SLI with MSI X58 Platinum SLI BIOS, but not stable. I must RMA 1pcs after 3 days
    Here is my result
    MSI X58 Platinum - BIOS v3.0 beta 3 (MSI X58 Platinum SLI BIOS)
    Core i7 965 EE@3.2Ghz
    3x1GB Corsair XMS 1333C9
    2 x MSI 9800GX2 - SLI
    Corsair HX1000W
    VISTA SP1
    Forceware 180.60
    Futuremark 3DMark Vantage
    PhysX - disable
    Futuremark 3DMark Vantage - MSI 9800GX2 - 12176
    Futuremark 3DMark Vantage - 2x MSI 9800GX2 SLI - 19520
    May 2007
    Ubatuba, Brazil.
    Quote Originally Posted by tranngocminh View Post
    Here is my result
    Corsair HX1000W
    VISTA SP1
    Forceware 180.60
    PhysX - disable
    I think MSI X58 PLATINUM is a good motherboard for its cost.
    Mar 2006
    Hastings, England
    how did you flash the sli bios to the board. I tried with afudos and got a ID error
    If you are really extreme, you never let informed facts or the scientific method hold you back from your journey to the wrong answer
    Sep 2007
    Quote Originally Posted by jabski View Post
    I use AFUWIN
  18. #18
    Mar 2006
    Hastings, England
    can you test wether you can use over x24 multi with that bios please
  19. #19
    Xtreme Member sinister1st's Avatar
    Dec 2004
    California
    Quote Originally Posted by s3rv3r View Post
    Nicce s3rv3r what cooling you using bro?
    Threadripper X1950
    MSI X399 GAMING PRO CARBON
    PCPOWER&COOLING 950@one solid rail.
    NOCTUA
    Windows 10
    CRUNCHIN'EM FOR XS
  20. #20
    Sep 2007
    With MSI X58 Platinum and Eclipse SLI, I can't increase ratio over 24
    I 'll send you all BIOS i have, check your mail
  21. #21
    Mar 2005
    Bay Area, CA
    What happens when you hold the multi @ 20 and bump the bus speed? how high can you go there??
  22. #22
    Mar 2006
    Hastings, England
    i got to about 170fsb
  23. #23
    I am Xtreme
    Oct 2007
    Down South USA
    I now have new (old) mobo MSI platinum,new cpu i7 920 and ram g.skill 1333. I have also added Danger Den water block (as I do not think swiftec is going to release an adapter for my apogee gt)and have it oc'd right now to 4.099 ghz. What a cpu. It does it without breaking a sweat. My temps, from coretemp, are ~38 idle and ~68 load via stress testing by prime95
    i7 920 oc'd 4.25ghz
    Asus P6T mobo
    EVGA GTX 260 x2 sli
    MCP655 pump
    TC 120.3 rad
    Swiftech MCR-220
    MM U2-UFO CYO
    Windows 7 RC
  24. #24
    Apr 2004
    Any news on this? I just ordered a x58 Platinum non SLI but I want to run 2 gtx260 in SLI
