For my first LN2 session I assembled one beast of a test bench. My aims were 6Ghz 3d stable, which I didnt get working until 2:30AM and I passed out at 3AM so not much testing. I also wanted to push my 8600 because I have seen a few of the same batch doing 6.2-6.3 3D stable, and 6400-6500 1M's. With no coldbug even at -140° I think I may have a winner on my hands here. The REX was a pleasure to work with. Great ram clocking, awesome stability at super high FSB and clocks, and one hell of an extensive BIOS! Great job Asus.
The CPU pot I had is OK at best for LN2 benching, its much better for DI. Temps swing wildly under load, and when pouring. The best I can do is keep it within a 10° range fluctuation. I had it @ -110 to -120 for most of the session. *Sees an F1EE in his future*
Hardware Setup:
e8600 820Axxx -140°C lowest tested no CB yet
Duniek Copper/Aluminum stepped pot w/ Fluke 52S thermometer
2x 4870x2 w/ Asus TOP Bios stock heatsinks/no mods. (max 850/960)
2x Dryer tube pumping 2°C air into the GFX Cards w/ 2x Delta fans (a 140CFM and a 240CFM)
2x1 GB CSX Diablo (good up to 1080Mhz 8-7-6-18-1T@2.1v or 980Mhz 7-6-6-15-1T@2.1v)
Asus Rampage Extreme (Booted at down to -115°C, not CBB yet either)
Duniek Northbridge Copper/Aluminum Pot mounted onto existing heatsink assembly (removed waterblock). Not going too cold here because of condensation issues
Xion 800 Watt
Xitech POST Code PCI Card
Vista 32 Home vLited
Bios Setup:
600FSB (no setfsb)
1.9 vCore
1.45 vTT
2.1 vDIMM
1.65 vNB
loadline disabled (keep rebooting during windows splash screen if enabled)
Ram set 7-6-5-15-1T all else on Auto. 333Mhz 5:8 strap, memset the subtimings.
