Neat little program, a nice addition to this would be a simple core temperature tracker.
Lian-Li Armorsuit PC-P80 Asus P6T Deluxe w/ OC Palm| TFC X-Changer 360 x2
Intel i7 965 Extreme Edition | Swiftech Apogee GTZ
Asus GTX 295 x 2 (Quad-SLi) | Koolance VID-NX295 x 2
Velociraptor 300GB | Swiftech MCP655 Pump x 2
G.SKILL PI Black 6GB | EK 250ml Reservoir
Tygon 7/16 Tubing | Enermax Revolution 85+ 1050w Fully Sleeved
hi,
now new as a part of MaxxPI²'s memory benchmark,
as preview-version (Memory/Latency, v1.05):
www.maxxpi.net
cu
hi,
update MaxxPI² - PreView - Single to v1.41
• v1.41, Batchmode added (18/06/2009) NEW!
cu
hi,
MaxxPI² - PreView - Multi
This benchmark uses as formula the Chudnovsky algorithm, unlike the MaxxPI ² - PreView - Single that use the Gauss-Legendre algorithm. The advantage of the Chudnovsky algorithm is, that principally, multi-core capability is possible. MaxxPI ² - PreView - Multi use this. That
means: That all available CPU cores work together on a single calculation. It was made sure that all CPU's equally served.
Technical:
MaxxPI² - PreView - Multi needs at least a dual-core processor and supports in the current version 1.07 CPU's with 2,3,4 and 8 Core's.
So the benchmark will only run on CPU's, with more than one core (HT core counts as real core, so 1+1HT core will accepted).
Maximum depth of calculation:
268.435.456 decimal places
•v1.07, initial public release (16/07/2009) NEW!
cu
hi,
update MaxxMEM² - PreView to v1.07
* v1.07, improved CPU detection (24/07/2009) NEW!
download: http://www.maxxpi.net/pages/downloads.php
and MultiPI`s scaleability http://www.maxxpi.net/pages/descript...aleability.php
cu
hi,
MaxxMIPS² - PreView v1.45
Pure CPU benchmark (CPU String/Integer -part, ALU)
- v1.45, initial public release (10/09/2009) NEW!
cu
for how long internal beta testing will continue?
nice utilities btw
CPU: Intel Core i5-2500K @ 4.4GHz (Turbo Mode) Mobo: ASRock Z68 Extreme3 Gen3 Air Cooler: Scythe Mine 2
GPU: MSI Radeon HD6870 Twin Frozr II RAM: G.Skill F3-12800CL9-4GBXL PSU: OCZ Fatal1ty 550W
Case: Antec Twelve Hundred OS: Windows 7 64-bit
[SIGPIC][/SIGPIC]
hi,
update MaxxPI² - PreView - Single :
# v1.60, major algorithm change from Gauss–Legendre to Chudnovsky (16/10/2009) NEW!
for much better scaling on *all* cpu types.
www.maxxpi.net
cu
hi,
for the intressed reader:
Memory all inclusive view
Mips scaleability
Flops scaleability
cu
these seem like nice programs and they stress the cpu a fare bit unlike super pi, they could b a nice stability tester i will look more into them for that
Dragon
http://smbach.com/mad.gif
Opty 175 Rig
Lian-Li PC75B case, Thermaltake BT w/ 165 CFM delta fan, Enermax 550watt PSU (36A on 12+), x1950 Pro, DFI Lanparty NForce 4 Ultra-d (moded for SLI so that i can use the second slot at 8x), Opteron 175 CCBWE 0547 TMPW (2.80, 280x10, 1.5 volts), 2x1gb Mushkin Redline xp4000 (280 3-3-2-8, 2.65 volts), 80GB WD
AM3 Rig
Lian-Li PC-75b case, Asus Crosshair III Formula, 965 x4 C3 @ 4.1 1.525 volts 2.8 NB 1.25 volts, 2x2gb Dominator GT Cas 8 2000Mhz@ 1720 6-6-5-18-22 1.725 volts, Asus 5770 VT @1010/1435, Seasonic 850watt PSU 2x12v rails 40 amps each, 36GB raptor boot drive, 80GB WD storage drive, HeatKiller LT cpu block, BI GTX 360 with 6x Scythe 3000RPM fans in push/pull, MCP 655 variable pump on setting 5, EK 150ml res, all 1/2 inch
DFI NF4 BIOS Guide
hi,
comming soon: first HWbot step, of 2(3)
best
update,
MaxxMEM²-PreView:
* v1.73, MaxxPI.net / HWbot.org submit added (30/12/2009)
update for:
MaxxPI²-Multi-PreView
* v1.55, support for upcomming new 6/12 core CPU's added (03/01/2010) NEW!
MaxxMEM² - PreView
* v1.74, minor bugfixes (03/01/2010) NEW!
Download
cu
hi,
for interested readers:
Vcore characteristics
cu
This benchmark doesn't seem to benefit much from HT.
--Matt
My Rig :
Core i5 4570S - ASUS Z87I-DELUXE - 16GB Mushkin Blackline DDR3-2400 - 256GB Plextor M5 Pro Xtreme
sure it does. HT benefit is only then possible, if the used routine don't use *much real* CPU power, this is *not* seen with classic taskmanager.
Performance Monitoring Unit (PMU) is the key. if there is a very high useage
(maxxpi peaks there about >85%) then there is nothing for HT to give for.
and dont think that HT will give you twiche performance
normally enabling HT at i7 9xx will give you a plus ~400-600mhz and that quite fine for *virtual* cores
best
yes it is. thank you, but this three:
Mips scaleability
Flops scaleability
are also very nice
best
My Rig :
if its so, sorry for that. english is not my native
well, not *much* right,
because as i said: Monitoring Unit (PMU) is the key.
if there is much load on this, HT will give you not much (because there is nothing to give for).
in worst Case: *lower* performance then without.
best
hi,
update for:
MaxxMEM² - PreView
* v1.80, maintenance update, Quick compare added (19/04/2010)
Remark for Quick compare:
with this, you can very fast see how your memory subsystem
perform-> red-yellow-green.
based on the MaxxPI DB, which contains low-end PC's
and highly/extreme overclocked ones.
cu
cu
hi,
MaxxGC² - PreView:
MaxxPI² - Introducing
cu
MaxxMEM² - PreView 1.96
http://www.benchmarkhq.ru/files/MaxxMEM2_preview.zip
http://www.maxxpi.net/pages/downloads/maxx...2---preview.php
-maintenance update, improved CPU detection
Need a Gigabyte latest BIOS?
Z370 AORUS Gaming 7,
GA-Z97X-SOC Force ,Core i7-4790K @ 4.9 GHz
GA-Z87X-UD3H ,Core i7-4770K @ 4.65 GHz
G.Skill F3-2933C12D-8GTXDG @ 3100 (12-15-14-35-CR1) @1.66V
2xSSD Corsair Force GS 128 (RAID 0), WD Caviar Black SATA3 1TB HDD,
Evga GTS 450 SC, Gigabyte Superb 720W
XSPC RayStorm D5 EX240 (Liquid Ultra)
NZXT Phantom 630 Ultra Tower
Win 7 SP1 x64;Win 10 x64
