Results 1 to 10 of 10
Thread: e8400 vs q9550 vs q9650
    Oct 2008
    Leeds UK
    Question e8400 vs q9550 vs q9650
    I have an E8400 @ 4.0Ghz at the moment, do you think i should upgrade it to one of these suckers? if so which?
    I know both can go to 4.0Ghz, although the Q9550 needs a beefy voltage., however, is it worth the extra ~£150 to go for the 9650??
    hmmm..which is better...theres only one way to find out....FIGHT!
    but really, will there be a performance increase over my 4.0ghz e8400?
    Banned
    Oct 2006
    Haslett, MI
    Quote Originally Posted by retrogamer1990 View Post
    Yes, huge. If 4Ghz is what you want, go for the Q9550, if you want 4.2 - 4.4, 4.5Ghz go for the Q9650. Be sure you have a good mobo though.
    Apr 2008
    Depends on what you do. If all you do is game, then no, the upgrade to a quad isn't worth it. Do you fold? Encode DVDs or edit video? Do anything remotely multithreaded? If you don't do anything multithreaded, there really is NO point to getting a quad.
    Hell, I "downgraded" from a Q6700 to an E0 E8400 and I'm much happier. Note that the Q6700 was at ~3.6GHz and the E8400 is at 4.5GHz. Even though I fold, I like the dual better. The nVidia GPU client is so much better at folding (on a GTX 280) than the SMP client that I really don't miss the PPD from the quad, which wasn't all that much better to begin with.
    • i7 920 D0 // eVGA X58 SLI // 12GB G.Skill Ripjaws // HD6950 (6970 BIOS)
    • Apogee XT // MCP655 // Thermochill PA120.3 // CM HAF 932
    • OCZ Vertex 3 MI edition // ASUS Xonar DX // Corsair TX850
    • HTC Incredible - Uber Kingdom Revolution ROM
    Oct 2008
    Leeds UK
    Quote Originally Posted by YMAA View Post
    if so can you tell me what settings you used to get it to that? you have an almost identical mobo too. im stuck at 4ghz.
    help would be appreciated!
    thanks for both replies btw
    Oct 2008
    Leeds UK
    please? threads seem to die really easy on this forum, cos there are so many users
    Feb 2008
    Russia
    retrogamer1990
    If you have P45 then you go for quads. If you have X38/X48 then you go for dual core. You decide.
    Intel Q9650 @500x9MHz/1,3V
    Asus Maximus II Formula @Performance Level=7
    OCZ OCZ2B1200LV4GK 4x2GB @1200MHz/5-5-5-15/1,8V
    OCZ SSD Vertex 3 120Gb
    Seagate RAID0 2x ST1000DM003
    XFX HD7970 3GB @1111MHz
    Thermaltake Xaser VI BWS
    Seasonic Platinum SS-1000XP
    M-Audio Audiophile 192
    LG W2486L
    Liquid Cooling System :
    ThermoChill PA120.3 + Coolgate 4x120
    Swiftech Apogee XT, Swiftech MCW-NBMAX Northbridge
    Watercool HeatKiller GPU-X3 79X0 Ni-Bl + HeatKiller GPU Backplate 79X0
    Laing 12V DDC-1Plus with XSPC Laing DDC Reservoir Top
    3x Scythe S-FLEX "F", 4x Scythe Gentle Typhoon "15", Scythe Kaze Master Ace 5,25''
    Apple MacBook Pro 17` Early 2011:
    CPU: Sandy Bridge Intel Core i7 2720QM
    RAM: Crucial 2x4GB DDR3 1333
    SSD: Samsung 840 Pro 256 GB SSD
    HDD: ADATA Nobility NH13 1GB White
    OS: Mac OS X Mavericks
    Jan 2007
    Norway
    Quote Originally Posted by WaterFlex View Post
    retrogamer1990
    So P45 is better for quad than X48? Why?
    DFI Lanparty DK P55-T3eH9
    DFI UT X58//DK P45-T2RS Pluss/ MI P55/ BI 785G
    E8600/ i7 920/ i7 860
    G.Skill Ripjaw 2000MHz cl9 2x2GB
    Corsair 3x1GB 1600MHz cl7
    OCZ Flex XLC 9200 2x1GB @1200MHz
    ATI 4850//Corsair HX1000W/
    When everything goes wrong: HP TX2590eo
    Aug 2008
    East Troy Wisconsin
    No consideration for the new i7's?
    Feb 2008
    Russia
    1. 2. 3. 4. 5. 6.
    LG W2486L
    Oct 2008
    Leeds UK
    thats a strange sig pic.
    but anyway, i7 = new intel xtreme mobo. new ddr3. expensive stuff.
    I want a quad for future proof-ness, benchmarks, gaming, multitasking, all that.
    thanks for the linkys
