I'd like to apologize for my post and delete it if possible. Unfortunately I was quoted twice, so it's all for moot.
>> i5 750 @ 3.6Ghz | CM212Plus + P12 | P55-UD3R [BIOS F2] | 4GB G.Skill CL8 | Zotac GTX 580
.: 4 x 1TB WD | Corsair TX750 | Lian Li PC-A70A | X-Fi | Logitech Z-2300
board in stock @ Germany, my hand is flying around the trigger .... hmm. It sounds really tempting to try how far can this board push the i7 920. Sadly, haven't got a tri-channel kit and 1366 mounting on coolers :sigh:
Sometimes a good slap in the face is all you need
Bios my arss.....
I can fix this problem with a hardware mod.... Hipro5
"Overclock till death. Overclocking is life." Hipro5
Just a note--NewEgg has these for $270. Making it probably the best board at the sub-$300 price point.
My toys:
Asus Sabertooth X58 | Core i7-950 (D0) | CM Hyper 212+ | G.Skill Sniper LV 12GB DDR3-1600 CL9 | GeForce GTX 670-2048MB | OCZ Agility 4 512GB, WD Raptor 150GB x 3 (RAID0), WD Black 1TB x 2 (RAID0) | XFX 650W CAH9 | Lian-Li PC-9F | Win 7 Pro x86-64
Gigabyte EX58-UD3R | Core i7-920 (D0) | Stock HSF | G.Skill Sniper LV 4GB DDR3-1600 CL9 | Radeon HD 2600 Pro 512MB | WD Caviar 80GB IDE, 4TB x 2 (RAID5) | Corsair TX750 | XClio 188AF | Win 7 Pro x86-64
Dell Dimension 8400 | Pentium 4 530 HT (E0) | Stock HSF | 1.5GB DDR2-400 CL3 | GeForce 8800 GT 256MB | WD Caviar 160GB SATA | Stock PSU | (Broken) Stock Case | Win Vista HP x86
Little Dot DAC_I | Little Dot MK IV | Beyerdynamic DT-880 Premium (600 Ω) | TEAC AG-H300 MkIII | Polk Audio Monitor 5 Series 2's
Traditionally Biostar may be a budget MB manufacturer but I don't think this is meant to be a budget board. Maybe by x58 standards it cut just one corner I can note and that would be having only 6 sata connectors. Other than that this should be a solid board... If DFI doesn't hurry up maybe I'll consider buying this instead!
Current: AMD Threadripper 1950X @ 4.2GHz / EK Supremacy/ 360 EK Rad, EK-DBAY D5 PWM, 32GB G.Skill 3000MHz DDR4, AMD Vega 64 Wave, Samsung nVME SSDs
Prior Build: Core i7 7700K @ 4.9GHz / Apogee XT/120.2 Magicool rad, 16GB G.Skill 3000MHz DDR4, AMD Saphire rx580 8GB, Samsung 850 Pro SSD
Intel 4.5GHz LinX Stable Club
This should be in the same faith as the TPower P45--I'm highly considering buying this board for $270-280 shipped
My toys:
Just ordered one from the egg this morning and over-nighted it. I should have it in place sometime this weekend, if all goes well. I am using an Asus P6T Deluxe right now, but have been very curious about this board for some time. My big concern is that it won't run all 12gig of my ram. I'm hoping it can...
Asus P6T6 Revolution/Core i7 965EE
Vista Ultimate 64bit
BFG GTX295
6x2gig OCZ Platinum DDR3-1600
Samsung SH-S223Q
2 640gig WD's in raid 0
Areca ARC-1210
Auzentech X-FI Forte/Z-5500's
Corsair 1000w psu
My Tpower X58 boots fine with 222 MHz BCLK.
オタク
"Perfection is a state you should always try to attain, yet one you can never reach." - me =)
I just noticed Newegg has the following posted about this board.
Does anyone know anything about this? linkX58 OC record Core i7 940 WR 4.8GHz
The Biostar TPower X58 has been available in the UK since last week - click the link below for details.
http://www.scan.co.uk/Product.aspx?WebProductId=928153
i5 2500K @ 4.9GHz MSI Z77 MPower G.Skill Trident 8GB 2400C10
EVGA GTX 1070 SC 8GB @ 1784/4004MHz Corsair HX 750 PSU
Samsung 830 256GB Creative ZxR Thermalright Silver Arrow
NEC 24WMGX3 24" TFT Fractal Design Define S Win 7/10 64bit
Had to dig through my emails from Biostar for the link.
http://valid.canardpc.com/show_oc.php?id=448862
That's really nice! I like how the multiplier is 23 -- the only reason IMO to buy a 940 is because it has a 24 multi. So I think this board with a 940 would be really special. The more I think about it the more I'm deciding to go with this board. Sure it only has 6 SATA ports, but I only have 6 hards drives (4 raid 0, 1 ram drive, 1 data drive) so it should be OK. I'm still a bit nervous though... Having always used asus, gigabyte, or DFI...
Thanks again for posting that link. What a monster overclock. I wonder what type of cooling they used. ((off to google it))
IDEM , it boots fine like that : http://valid.canardpc.com/show_oc.php?id=462889
***** Visit us on PCWorld.fr *****
Any word on how this board does with 12gig of ram installed?
BFG GTX295
Samsung SH-S223Q
Areca ARC-1210
Corsair 1000w psu
Board installed. It DOES work with 12gig ram!!! Sweet! Just as a quick benchmark, all settings the same as I had with my P6T Deluxe (except ram is at 1333 2T now, on P6T it was at 1333 1T). I got over 1000 points higher in 3dMark2006. Now, I know it doesn't mean alot, but it just tells me that this is going to be one awesome board!!!
BFG GTX295
Samsung SH-S223Q
Areca ARC-1210
Corsair 1000w psu
One negative about the board so far and it was in the packaging, so it's not really a big deal at all. The stickers that are on the board, ie the ones that cover the lower pci-express slots and the memory slots would not come off very well. It took me an hour to make sure that all of the sticky parts left behind were completely removed and that none had gotten into the slots. Alot of boards have these, which are just for looks, but this is the first board I have tried out that they didn't actually just pull right off. Very crappy, but still only a cosmetic hit.
As far as operations go, however, this thing is a heck of alot more stable than the Asus P6T Deluxe that I replaced it with!
BFG GTX295
Samsung SH-S223Q
Areca ARC-1210
Corsair 1000w psu
^^^ Please edit from now on instead of doing a double, then triple post...^^^
Anyways this is a killer board in the same fashion as their boards for P45... great bang for the buck!
Hi, got a few questions if you dont mind answering.
1) Does the T-Power II Utility work fine with Vista x64bit?
2) Can someone display bios screens?
3) Are the voltage increments the same as Gigabyte/Asus X58 boards?
4) Has anyone compared this board to Gigabyte/Asus X58 boards in terms of benchmarks? How does it compare?
Tpower II shows temp at 33C all the time, and use auto fan setting sets my CPU fan at 0%. My Zalman 9700 fan won't spin up even though it has a manual control with TpowerII .I used that to update BIOS because BIOS update failed from boot up. I don't think Tpower II is reporting the temperture right.
I sent an email to Biostar and uninstalled it for now until I hear back from them.
I got my Tpowerx58 at Superbiiz for $229+ shipping, I don't see it listed anymore.
I am also have heat problems overclocking it beyond 166MHz Bclk, can't pass Prime 95, too hot.
I have no issue running the T-Power II Utility on Vista64. I did some basic benchmarks with the hardware in my sig on both the P6T Deluxe and the T-Power and with everything at default/stock, the T-Power was faster. I know that 3DMark2006 is old and hated, but I got about 1000 points higher overall with the Biostar. As far as the voltages, I believe they are in the same increments.
BFG GTX295
Samsung SH-S223Q
Areca ARC-1210
Corsair 1000w psu
Well I haven't got the board but have you tried updating the bios via a USB stick? Also have a look on the Biostar website, maybe a newer version of TPower II compared to the CD you recieve with the motherboard.Thanks for the info, I looked on The Rebels Haven forum, found some quite useful infomation there.
Click Here >> Biostar 64 Bit Intel S1366 Motherboard - The Rebels Haven Forum! (Unofficial Biostar Forums)
http://www.matbe.com/articles/lire/1...--alternative/
Test , Pictures and Bios here
I've just read on "The Rebels Haven Forum" that their isn't no setting for 1333mhz under Dram Frequency.
How do you go about getting 1333/1600 & higher?
I'm guessing this needs addressing within a bios update, are the MSI/Gigabyte/Asus/Foxconn/DFI boards etc the same?
Thanks, nice review but it's in French was only posted today, I used google translator & here is the link: Biostar Tpower X58: the alternative! @ matbe.com
