I found a GE GXCF05D water dispencer. Would it be possible to build a Vapor Phase Change Cooler out of it? How much work would it take to modify it for use in a PC? Thanks.
It's not as easy as putting together a watercooling setup. Read the stickies and search for "worklog" or "DIY" or "my build" and things of that nature to do a little research and when you have specific questions ask them and I guarantee you will get more responses.
Hey Guys, Thanks for your response. I've been having the forgot-my-password blues! I dismantled my chilled water dispenser and removed the compressor and tubing intact. I turned the unit on and the compressor never responded. I can't see wasting more time on that project. I'm O.K. with aircooling.
How do you know that it didn't respond? Did you have a pressure gauge hooked up?
It's just that compressors that small can't be heard at all. So if you were listening to hear it start, they say nothing. If you touch it, you can feel some very small vibrations.
OCTeamDenmark.com Crew
Cooled and sponsored by Coolerkit.dk
CPU: E8600 @ 4000 MHz
Mobo: Biostar Tpower I45
RAM: 2*2 GB OCZ PC-6400 @ 800 MHz 4-4-4-12
GFX: Zotac GTX280
I didn't have a pressure gauge. I plugged it in and felt for vibrations and there were none. There were two switches and three LED's on the unit. One switch for hot water. One switch for cold water. One LED for power (Green) which came on when I plugged the unit in. One LED for hot water (Red) which came on when I turned on the hot water switch. One LED for for cold water (white) which would not come on when I turned on the cold water switch. I tried the switches for a while and the compressor never vibrated and the copper tubing never changed in temperature. The whole unit had been dropped from a considerable height when it was discarded. It had landed upside down hard enough to bend one of the metal side panels. That probably damaged the compressor.
