E8600 - Q820A599
Kingston HyperX PC3 11000 DDR3 1375MHz (KHX11000D3LLK2/2G)
I was having trouble with stability issues even at 4.0GHz (500*8) using the 1:2.665 divider to run my memory at 1333MHz so in a fit of absolute frustration I set the FSB to 400MHz, the mutli to 10 and the memory divider to 1:4 CPU400 and low and behold instant stability with a minor memory voltage adjustment.
Even though I am now limited to 4.0GHz cpu (400*10 as the 1:3.2 divider doesn't appear to work either, probably needs more tweaking but I have to go to work ) I'm quite happy with the result despite the fact my memory is slightly overvolted at 1.725V (there is no 1.70V option )
Stability testing to continue tonight.
Current settings:
CPU Clock Ratio Unlocked ................ Enabled
CPU Clock Ratio ............................. 10 x
CPU Clock Ratio + 0.5x ................... Disabled
Target CPU Core Speed .................. 4000
CPU Clock (FSB) ............................ 400MHz
CPU Clock vs Memory Speed ............ 1:4 CPU400
System Memory Speed ................... 1600MHz
CPU Clock Skew Control .................. 300 ps
CPU Clock Amplitude Ctrl ................. 800 mV
PCI Express Clock .......................... 100MHz
PCI Clock ..................................... 33.6MHz
Spread Spectrum ........................... Disabled
Over Clock Recovery ...................... Enable
All Voltage Control Sub Menu
********** Affect CPU MHz **********
CPU Voltage Multiplier ..................... x 1.000
CPU Voltage setting ....................... 1.225V
CPU Target Voltage ....................... 1.225V
CPU Current Voltage ...................... 1.2112V
CPU Default Voltage ....................... 1.2250V
CPU Vdroop Compensation ............... Disabled
********** Affect FSB MHz **********
CPU PLL Voltage Setting ................. 1.50886V
CPU VTT Voltage Setting ................ 1.200V
CPU GTL Ref . 0 Voltage .................. Default
CPU GTL Ref . 1 Voltage .................. Default
CPU GTL Ref . 2 Voltage .................. Default
CPU GTL Ref . 3 Voltage .................. Default
NB Voltage Setting ........................ 1.250V
NB GTL Ref . Voltage ...................... Default
SB Voltage Setting ........................ 1.500V
******** Affect Memory MHz ********
DRAM Voltage Setting .................... 1.725V
DRAM Pull-Up Voltage ..................... Default
DRAM Pull-Down Voltage ................. Default
DRAM Ref . Voltage ........................ Default
