Couldn't wait for my Coolermaster ATC and 965 to come in so I crammed what I had into my CM690 case(940 ES). Sore Knuckles, but it was worth it. Just some shots to show the layout if anyone is interested.
Now unpacked !
Now unpacked !
975 XE @ 4.0GHZ - Thermaltake TRUE REV 3
12GB Corsair Dominator 1600MHZ
EVGA 132-BL-E758-A1
2 X Gigabyte HD5970's CFX
2X Runcore Pro IV 128GB SSD's in RAID 0 & 2X 2TB WD Enterprise in RAID 1
2X Plextor 810SA DLDVD SATA
Thermaltake 1KW Toughpower
Coolermaster Sniper
Dell 30" 3007FPW
HEAT - Randy2
Pretty busy insides. No cable management?![]()
My toys:
Asus Sabertooth X58 | Core i7-950 (D0) | CM Hyper 212+ | G.Skill Sniper LV 12GB DDR3-1600 CL9 | GeForce GTX 670-2048MB | OCZ Agility 4 512GB, WD Raptor 150GB x 3 (RAID0), WD Black 1TB x 2 (RAID0) | XFX 650W CAH9 | Lian-Li PC-9F | Win 7 Pro x86-64
Gigabyte EX58-UD3R | Core i7-920 (D0) | Stock HSF | G.Skill Sniper LV 4GB DDR3-1600 CL9 | Radeon HD 2600 Pro 512MB | WD Caviar 80GB IDE, 4TB x 2 (RAID5) | Corsair TX750 | XClio 188AF | Win 7 Pro x86-64
Dell Dimension 8400 | Pentium 4 530 HT (E0) | Stock HSF | 1.5GB DDR2-400 CL3 | GeForce 8800 GT 256MB | WD Caviar 160GB SATA | Stock PSU | (Broken) Stock Case | Win Vista HP x86
Little Dot DAC_I | Little Dot MK IV | Beyerdynamic DT-880 Premium (600 Ω) | TEAC AG-H300 MkIII | Polk Audio Monitor 5 Series 2's
EVGA 132-BL-E758-A1
Coolermaster Sniper
Dell 30" 3007FPW
HEAT - Randy2
Benchmarks, benchmarks please!!! ((: I love it, love it man! (:
ASUS P5E Deluxe X48 | C2Q Q9550@testing[Fuzion v2+MCR320+MCP655] | G.Skill 4x2GB F2-8800CL5D-4GBPQ@testing | Sapphire 4870X2@ testing | 150GB WD VelociRaptor + 2xWD6400AAKS | Chieftec CFT-850-14C | Iiyama E2403WS | Razer DeathAdder | CM CosmosS Black
That cooler is a beast. Reminds me of a V8.
I reccomend some zip-ties for cable management. Cheap & strong.
E8400 @ 4.0 | ASUS P5Q-E P45 | 4GB Mushkin Redline DDR2-1000 | WD SE16 640GB | HD4870 ASUS Top | Antec 300 | Noctua & Thermalright Cool
Windows 7 Professional x64
Vista & Seven Tweaks, Tips, and Tutorials: http://www.vistax64.com/
Game's running choppy? See: http://www.tweakguides.com/
Main Rig
Intel Core i7 920 CPU @ 4.2Ghz D0
Asus Rampage III Formula Motherboard
Corsair Dominator 3X2GB 1600Mhz DDR3 CAS 8
ASUS GTX 680 DC2O 2GB DDR5 (Stock Speeds)
Corsair TX850W v2 TX Power Supply 70A 12V Rail
Swiftech Apex Ultima Kit w/ Apogee GTZ WB
2X Seagate 333AS 1TB 7,200 32MB HD's in RAID 0
1X OCZ Vertex 3 128GB
Windows Vista Ultimate X64 Edition
Coolermaster Cosmos S Case
Asus ProArt PA248Q 24" IPS LED Monitor
Samsung 20" SyncMaster 2032NW 3000:1
UNOFFICIAL Rampage II Extreme Thread
Which ram you got there mate ? Gskills ?
Question : Why do some overclockers switch into d*ckmode when money is involved
Remark : They call me Pro AsusSaaya yupp, I agree
EVGA 132-BL-E758-A1
Coolermaster Sniper
Dell 30" 3007FPW
HEAT - Randy2
My toys:
Well,
packed in this tight of a case, I have a 940 ES @ 3.2, and it idles about 43C and climbs to mid 50's with a 100% load. I don't know what people are getting with the stock fan, so I don't know if that's good or bad. I have a 965 EE, and a Coolermaster ATC case on the way, and should be here tommorrow, so I'm curious what that will do as far as temps around 3.6GHZish.
I can tell you that this set-up is much quieter than the Zalman CNPS9700 I had in here before. Same case and fans, but the switch to the V8 from the Zalman.
EVGA 132-BL-E758-A1
Coolermaster Sniper
Dell 30" 3007FPW
HEAT - Randy2
Don't know if I will get around to any benches until I get the 965 in there. I didn't have the time to do a clean Vista install, I just migrated the old OS over, and that was a RAID 0 and RAID 1 array. The P6T picked the old arrays up fine, but there's a few quirks. So I'll hold off on the benches until I get a clean install on here.
EVGA 132-BL-E758-A1
Coolermaster Sniper
Dell 30" 3007FPW
HEAT - Randy2
Awesome hardware
Need a better case for cable management.
where do u get the V8 with LGA 1366 in the USA?
Asus Rampage II
Core I7 920 O/C 3.8
Mushkin 6gig 7-8-7
ATI 4870X2
PCP Turbocool 860
Mountain Mods Pinnacle 24
Koolance CPU-350 AC
FSR 360
pa 120.2
EVGA 132-BL-E758-A1
Coolermaster Sniper
Dell 30" 3007FPW
HEAT - Randy2
Which store ??
Rampage 2 Extreme's have just landed at the wholesalers. Picking up a couple tomorrow.
Should be a good comparison coming up. Building two systems up using i7 extremes / Rampage 2 Extremes / OCZ gold tri channel.
One system is using Tri Sli with GTX 280's and the other with 4870 X2's in crossfire.
OCZ SS drives and Vista 64
Everything is being watercooled in both.
Core 2 Quad Q9650
Rampage Extreme
Corsair PC2 1800 4 gig
Cooler Master 1100w (M/B - Video)
OCZ 850w Modstreem (everything else)
2 x Gainward ATI 4870 X2 - 2048MB
2 x 60 Vertex SSD's (RAID 0) - System
2 x 120 Vertex SSD's (RAID 0) - Data
2 x 120 Vertex SSD's (RAID 0) - Backup
Hailea HC1000 Chiller
Everything under Chilled Water - 18 Degrees C
http://www.markostnetworking.com/pc_ref.htm
You'll love the case! What color did you get? Oh, and awesome setup you have going!
I am Xtreme
EVGA 132-BL-E758-A1
Coolermaster Sniper
Dell 30" 3007FPW
HEAT - Randy2
How cool does that make your CPU?
OC'd to 3750 @ 1.28V idle is low to mid 30's and and heavy loading is 60's. That is after honing the base flat. The V8 had about a .008" convex bottom on it out of the box, which is about the worst I have seen. Before honing, loads went op to 80's and idle was mid
40's. Keep in mind, this case is very well balanced so YMMV.
Kinda funny - the one charactersitic that makes or breaks a cooler and Coolermaster overlooks it.
EVGA 132-BL-E758-A1
Coolermaster Sniper
Dell 30" 3007FPW
HEAT - Randy2
GB 790XTA UD4
GSkill Pi Black 2000 Cas9
ASUS 4870
Enermax Revolution 1050+
http://www.heatware.com/eval.php?id=67661
