Alrighty, Getting some more work done this weekend. Picking up where I left off.
After the internal radiator was installed, it was time to get the 3 internal fans ready. Using liquid nails, I glued them together, and pressed them using a long slide clamp and two clamped boards kept them from bowing.
It was easy getting that far, then I had to come up with a way to suspend the fans over the radiator. It was clear that gluing any pieces to the side of the plexiglass would be too difficult, so I came up with a "truss" system.
First I drilled some holes.
Then I got out my trusty lincoln welding rods. They're the welding electrodes you find at lowes and they are nice and stiff. I sanded the flux off like so...
