Posting here, since it has most of my recent design pics and stuff.
I've got two pictures of the full chiller. The first one is before I started. Its a pretty big setup spanning nearly 5 feet. This is intentional. I've got a plan to contain it within a chest. The width of the chest depends on how well I can keep the tubing within decent parameters width wise. Currently, 18 inches is the width of the actual chiller. The chest will have to be at least 2 feet wide to house it with the sound insulation.
The other full size pic is from later on in the evening. Note that I didn't get a heck of a lot done. I had some trouble with the condenser. The last picture is kind of blurry, but its after the repair. The pre-repair photos didn't come out well. Basically, when I was adjusting the valve position in the right corner, the already cracked braze joint that I epoxied came lose. It snapped clean off. Luckily the epoxy was soft, so it peeled right off of the paint. The good thing is that I got to put the right size stub on the tube. It worked out okay and I repaired it just fine, but it killed my progress.
The third picture notes the pump placement. The condenser pump's volute has been turned so that it discharges at the bottom. It will make it easier to line up the system. The cooler pump will probably discharge to the right, but I'm still waiting for the new Volute, which is the front cover with the discharge nozzle and inlet.
Next week I'll be receiving the next slew of parts. The 5 x 3 rectangular tubes and 5 x 3 plates will be arriving. I'll be able to start building the reservoirs soon. Before that, though I've gotta get the tops cut out for filling and maintenance. I may just go with a 4" hole on the top center
