Results 1 to 11 of 11
Thread: Strange Blackops BIOS problem - Win Xp wont boot
    Sep 2008
    I did ask this in the G32 BIOS thread.. But since it wasnt asked i thought i might get an answer here lol
    Ok since updating the BIOS to G32 with my raid 0 setup - no worries at all!
    However this is providing i using 'OC GEAR' Overclocked settings 1 (forgot the name of it, but its just your saved overclock profile)
    Anyways - this was my stable overclocked settings whilst using G28 bios etc etc. But when i change settings - voltages etc i can no longer boot into windows, it will load into windows but freeze on the desktop before anything loads in the task bar.
    So i reverted back to g30 bios and tried to load with defaults with no luck at all, still freezing at the exact same point and making some funny noise in my headphones
    So then i loaded back up my Overclocked settings from 'OC GEAR" and booted up and perfect!
    So i guess what im asking is - why the hell cant i change any settings, and why will this ONE profile only work? O and i should mention changing settings in aegis panel does actually work ok
    I have E8400 @ 4.1ghz now
    PSU - 620 antec
    Blackops Board
    2gb of corsair 1600 mem
    Hope someone can give me an answer (saaya )
    Apr 2008
    Ireland
    Hi! Ryan12
    i have noticed that there is a glitch with the profiles between different bioses
    i was using bios g28 and had my most stable settings stored in profile 1
    when i went up to bios g30 which introduced new options in the memory settings page that were not in g28, when i loaded my profile created in g28 in to bios g30 the bios automatically set these new settings to values other than default which caused my board to become unstable, i am still trying to find the right values for these new settings
    i think this is also happing in g32, as it probably has new settings that are not in previous bioses and when you load a saved profile from a previous bios the board seems to act a bit weird
    i have not tried g32 as i find g30 works for me
    Raptor1
    Case: Lian Li PC-A7010B
    Motherboard: Foxconn Blackops X48 (G30 Bios)
    CPU: Intel Core 2 Duo E8500 3.16Ghz, Q812A232, (Running At 3.2 Ghz)
    Memory: Cellshock 4 x 1GB DDR3 PC3-1866 (8-8-8-16) Blue Dual Channel Kit (Running At 1600 Mhz)
    CPU Heatsink: Thermalight Ultra Extreme 120 With Scythe S-Flex SFF210G S-FDB 1900RPM 120MM Fan
    Graphics: BFG 9800 GX2 OC Driver 185.81
    Power Supply: Enermax Galaxy DXX 1000W EGX1000EWL ATX2.2 Modular PSU
    Sound: Creative X-Fi Fatality Pro
    Monitor: Viewsonic 19" VX1940w Widescreen LCD 1680X1050 2ms
    DVD Drive: LG GGWH20L Super Multi Blue Blu-ray Disc Rewriter and HD-DVD Rom Lightscrbe DVD±RW, DVD±R, DVD±R DL, DVD-RAM SATA
    Backup: Iomega REV 35GB SATA
    Hdd: OS - 2 x Western Digital VelociRaptor WD3000HLFS BackPlane Version 300GB 10,000RPM, 16MB SATA2 (Raid 0)
    Hdd: Storage - Samsung Spinpoint F1 1TB 7,200RPM 32MB SATA2
    OS: Windows 7 Build 7100 RC x64
    Bios Settings: http://www.xtremesystems.org/forums/...06&postcount=1
    Sep 2008
    Interesting because my settings from G30 - G32 in the overclocked profile has been the only thing that has maintained stable lol... Very odd and im just annoyed that i cant overclock any higher or lower because it simply wont let me touch anything
    Jun 2005
    Massachusetts
    It seems that once one changes BIOS, do not use stored profiles. I changed BIOS from PO2 to PO5, tried to load a saved profile from PO2 into PO5 and the pc would not boot after saving the PO2 profile under the PO5 BIOS.
    I solved the problem by using the BIOS jumper pin to force BIOS chip 2. Booted to windows and reflashed BIOS chip one. By forcing the BIOS jumper pin, one can essentially "hotflash" the corrupted BIOS chip in Windows.
    Since that time, I force the BIOS chip selection by using the selector jumper pin. If I flash a BIOS, it's with USB or floppy, selecting only that chip by jumper. I do not use a saved profile from one BIOS to another. Having used DFI boards with CMOS Reloaded, DFI stated quite plainly not to use stored profiles with different BIOS versions. I thought my experience was isolated, however, it was not. DO NOT USE stored profiles with different BIOS versions. This board is very robust and the dual BIOS helped me out when I corrupted my BIOS chip with a stored profile.
    Asrock Extreme 4 | 2600K | 16G G Skill | Powercolor LCS 7970 | PCP&C 910 Silencer | Crucial C300 + Intel X-25V + Raptors | D-Tek Fusion v2 | Swiftech MCR Drive 360 | HP LP2475
    Oct 2008
    QLD, AU
    Quote Originally Posted by Sailindawg View Post
    Asus boards (and I would suggest all boards) are the same.
    Jun 2005
    Massachusetts
    Sep 2008
    Ok, i will try to flash the main BIOS, however - as i said before.... ONLY that 1 stored profile will work.. Nothing else will work at all.
    I will flash the bios and see how i go thanks
    Jun 2005
    Massachusetts
    @ryan12
    Before you flash, set optimized defaults to guarantee that you are stable. Flash, reboot, set optimized defaults, reboot, then go into BIOS, set clocks that worked before, reboot. Now you should able to boot directly to windows.
    Sep 2008
    @ryan12
    Ok did what you said, but once i pressed ALT+F2 to flash the bios using G30 bios off of my floppy disk so then it started to flash it... and then it just was flashing 'please wait' for about 30 minutes so i figured nothing was happening so i rebooted and had to set back to my old overclock profile to be able to boot up into windows to type this lol.
    So im confused on what the problem is and why i cant flash the bios and only that one overclock saved setting will work.
    O and u mentioned u can use your USB instead of floppy, when i tried to use my usb stick it still kept looking for the floppy, is there something i need to change in the bios?
    UPDATE - I flashed back to G28, but even on everything on default windows would still not load.. So i just set my settings back to my old overclocked settings and booted up perfect. Weird thing cpuz says the bios is 6.00pg and the bios says G28?
    Jun 2005
    Massachusetts
    Koda made FoxKey to make flashing very easy. His latest image file has the most recent G32 BIOS. Give this tool a try!
    Sep 2008
    Nah it will flash the bios fine but still cant change any settings, guess the bios is just screwed.. I will just have to put up with not being able to just anything.
    There was little improvement i could change the FSB a tiny bit but would result in the system being unstable either way
