What do you do with your computer?
It's going to be hard to squeeze a fast quad core CPU and a mobo into $300 ...
If you do gaming and basic apps/web stuff, my recommendation would be to get the E8600. Overclocks really well, though I don't know the ins and outs of your motherboard at all.
If you really need a quad (heavy duty data processing, image processing, video, etc.) then the Q9550 would be a good use of your budget. I have OC'd mine to 3.4 GHz (on an Asus P5Q Deluxe P45 motherboard) with almost no effort - 100% on air with a TRUE just like you
EDIT: Oops a couple more things to mention:
- merely upgrading your motherboard isn't going to do a lot for you for performance, other than allowing future growth.
- with your current monitor, more GPU power is a waste of money. It just won't do anything for you.
- maybe the best use of your $300 is a new monitor? If you could find a 24" used at that price it would be a huge upgrade. I went from 20" to 24" this summer and it's one of the best ups I've ever done.
