Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 100
Thread: Thermalright TRUE all Copper at PPC's
  1. #51
    Aug 2006
    Greensboro NC
    Excuse the sloppy cables, I havent cleaned anything up after putting the board back in because I want to make sure nothing is going to break before I take the time to tidy up. I had to mod the Silverstone fan to make it work with the fan clips.
    i7 2600k@4.6Ghz 1.34v
    Coolermaster 212 Evo cooler
    Asus Z77 Sabertooth
    2 x GTX 470 EVGA SLI
    G.Skill 2x4 PC2133 DDR2
    Cooler Master 850W
    Rocketfish Full Tower
    Crucial M4 64 Gig
    WD 640 AAKS
    320 gig 7200.10
    ΜΟΛΩΝ ΛΑΒΕ
    http://www.flickr.com/photos/19737951@N07/
  2. #52
    Jan 2008
    Lubbock, Texas
    Quote Originally Posted by Tarowah View Post
    I installed mine today and it seems to be doing fine on on my 780i motherboard mounted vertical, I had my doubts about installing this monster but she is steady as a rock, I'll check in from time to time and will let you know if the thing rips my CPU socket off the board through the night lol.
    it might be fine at first but im pretty sure it won't be good in the long run. maybe a brace that supports it from the top of your case or something to take some of the weight off? might be hard to do tho and still have a good mount. but i believe the highest amd specification for a cpu cooler is like 600g and i think intel is 500g and most aftermarket coolers are already over that and the TRUE copper is quadruple that. would be nice to see pics tho. i want to see a TRUE gold now but that would be around $5000 i bet. and a gold mobo would be amazing if it was possible.
  3. #53
    Aug 2007
    Kent, Washington
    I would most definitely come up with some kind of bracket. Your mobo is probably screaming right now.
  4. #54
    The only ORB-Owning Camel On XS
    Mar 2004
    Ohio
    anyone else notice the fins on the TRUE Copper seem thicker than "average" fins?
    (thicker than the fins on the XP-90C also)
    my guess is this is why its scaling so well with > air flow compared to most HSs
    JoeCamel is FOLDing for... A CURE!!! 70+Ghz (please fold so i dont have to quit smoking. j/k)
    6800 EX Conroe @ 4740 MHz (395 x 12) - - Dry-Ice in The Camel Pipe -
    - X1900 CrossFire - - @ 846/945 -- MachII cooled Slave XTX - mOUSE-pOT cooled Master -
    - ASUS P5W-DH -- V-Mods: MCH, V-Core, V-Dimm - - 700w "Mr Zippy" PSU
    - Corsair XMS 6400 CAS3 - 2x gig @ 494 MHz 4-4-3-1
  5. #55
    Jan 2008
    True copper cooling a 4.6Ghz E8600 1.28v to ~40C load:
    http://img217.imageshack.us/img217/8834/4600dbu9.jpg
    Bring... bring the amber lamps.
    [SIGPIC][/SIGPIC]
  6. #56
    Jan 2008
    Lubbock, Texas
    what fan are you using?
  7. #57
    Mar 2007
    Bulgaria/Sandanski
    Q9550 4Ghz+TRUE Copper+1x120 Akasa Amber 1400 R.P.M.:
    Idle/Load:
    GA-X58A-UD9
    I7-970
    KHX2000C9D3T1K3 3 x 2GB
    HALE90-1000-M
    Test Bench V1.0
  8. #58
    Apr 2008
    Brazil
    nice results angelreaper, but this heatsink deserves a better fan, huh?
    maybe some Scythe Ultra Kaze, SanAce, Panaflow, even ADDA or Sunon... just for some testings
    i have 4 akasa amber laying at my closet... used them months ago in a quiet low-end computer
  9. #59
    Admin
    Feb 2005
    Ann Arbor, MI
    A single 1400RPM fan on this HSF is a mistake, plain and simple. Especially a bad one like the Akasa Amber.
    I've decided to release all my data at the end of testing, rather than trickle it out--as it is right now, a casual observer (someone just looking at graphs, or anyone who does not speak English) would get the wrong impression.
  10. #60
    Aug 2007
    South Wales
    guess it will need lapping like every other true i installed
    ** yes im back after a long absense. that means the liver transplant went well and i can continue to poison myself with more swedish vodka
    "Never under estimate the predictability of stupidity"
    Q6600 @ 3.6 / TRUE (both lapped)
    P5Q Deluxe
    4Gb Corsair DominatRIX 1066Mhz
    1Gb HD 4870 + HR03-GT
    2 x 320gb WD3200AAKS RAID-0
    Thermaltake Toughpower 850
    X-Fi Fatality / SR-71 Amp > Sennheiser HD650's & Logitech Z-5500
    HP W2207 TFT
    and me??? Powered by absolut, kebabs, tramadol & a new liver
  11. #61
    Aug 2006
    Greensboro NC
    I was going to ask if anyone had lapped theirs yet, I am on a stock mounting and not lapped. I wonder if lapping and the washer trick is even needed with this one? This is my first TRUE so I am still noobish about this sink.
    Asus Z77 Sabertooth
    Cooler Master 850W
    Crucial M4 64 Gig
    WD 640 AAKS
    320 gig 7200.10
    ΜΟΛΩΝ ΛΑΒΕ
  12. #62
    Admin
    Feb 2005
    Ann Arbor, MI
    I'll be lapping mine once I get full unlapped results done.
    Will be comparing to:
    HDT-S1284EE, lapped and unlapped, pushpin and hardmounting
    TRUE, lapped only (already lapped, can't unlap)
    IFX-14, lapped and unlapped.
    All 4 will be tested on an E6700 @ 3555MHz (395x9), 1.56v loaded (no, it doesn't need that...I just like making heat) and a QX6700 @ 3160 (395x8), 1.46v loaded (again, doesn't need that kind of volts for that lowly OC, but it's a lot of heat being made and can take temps and be stable up to tMax without issue ).
    Assuming all else equal, the QX should make 56% more heat than the E6700, with neither being a lightweight (both run hot...).
    On a horizontal mount, a high pressure washer setup did nothing for me on both my TRUE and TRUECu....on a vertical mount, I've seen it help my TRUE, but I won't be testing them vertically.
    EDIT: I'll also be testing short load vs. sustained load for temps....I have a feeling on a 'short load' (characteristic of benchmarking, not necessarily crunching, folding, encoding, etc.) the TRUECu will do especially well.
  13. #63
    -_-
    Sep 2006
    ATLanta, Ga.
    Quote Originally Posted by Vapor View Post
    In fact, dual 1300RPM fans on a TRUECu beats dual 2700RPM fans on an IFX-14 by ~2.4C average load and ~1C peak load temp.
    This is insane....just wow. If that kind of scaling continues, temps with high-speed fans will be incredibly low--a truly wonderful bench HSF (since it is, IMO, too heavy to mount in a vertical system).
    Then I'm not even gonna tell you what a 4600RPM fan pushing 220CFM does for this
    Now my testing will be nowhere near Vapors but as soon as I finish I will let you guys know
    Quote Originally Posted by Gautam View Post
    I'll add my name to this elpida graveyard as soon I even think about running 32M. (yes, the thought is enough)
  14. #64
    Mar 2005
    Imladris
    The beauty of air cooling.
    The little air system that could.
  15. #65
    Admin
    Feb 2005
    Ann Arbor, MI
    TRUEs love airflow
    The TRUECu is no exception
    Can't wait for some numbers on the 4600RPM fan, I'm only testing up till ~2700RPM, so I'm curious what it'll do
  16. #66
    Mar 2004
    Ohio
    that fan look sooo MEAN!!
    only thing i never liked about those monsters is the huge hub (dead-zone)
    wonder what a "push push pull pull" set-up would do
  17. #67
    Jan 2008
    Lubbock, Texas
    Quote Originally Posted by Joe Camel View Post
    at least the dead zone doesn't matter as much when the heatpipes are on the sides. maybe if u get one of those vans and mount the TRUE pointing up then you won't have to worry about weight when its on cause it will just propel itself up.
  18. #68
    Mar 2005
    Imladris
    I predict kill your hearing.
  19. #69
    Xtreme Mentor
    May 2008
    cleveland ohio
    this Copper vs aluminum seem like you need more CFM for copper then aluminum.
    HAVE NO FEAR!
    "AMD fallen angel"
    Quote Originally Posted by Gamekiller View Post
    You didn't get the memo? 1 hour 'Fugger time' is equal to 12 hours of regular time.
  20. #70
    Mar 2004
    Ohio
    i wouldnt go so far as to say it NEEDs it, more like, it can "take advantage of it" better than aluminum
    from an Air benching POV, this thing will KICK a$$
    the shier mass of it should eat an entire 1M run
    and ask for a 4M for dessert
  21. #71
    Oct 2008
    Florida..Tampa and St Petersburg
    that sink would look great on gigabytes p45 extreme matching the over top coper heat pipes they got going on the board...........you could anchor a boat with that thing
  22. #72
    Administrator andressergio's Avatar
    Jul 2007
    Montevideo - Uruguay
    A damn man !!
    and i tought i was crazy for putting 3 sanyo's on my thin rad
    Really amazing cooler the TRUE
    Intel Core i9-7980XE@ 4.8GHz 18C/18TH (Direct Die Contact)
    ASRock X299 OC Formula
    ADATA XPG SPECTRIX D80 (4x8GB) DDR4-3800C17 B-Die
    1x Intel Optane SSD 905P 480GB
    4x HP EX950 NVMe 2TB on ASRock ULTRA M.2 CARD
    EVGA RTX 2080TI KINGPIN 2190/8000 Stock Cooling AIO 240
    SilverStone ST1500W-TI TITANIUM
    Alphacool Custom Water Cooling
  23. #73
    Xtreme Mentor
    May 2008
    cleveland ohio
    I noticed that with the ultra kaze I got.
    too bad there aren't any scroll fans that fit it 120mm spot.
    but then you most liekly need a duct to keep it all going into the fins.
    HAVE NO FEAR!
    "AMD fallen angel"
  24. #74
    Mar 2007
    41°6′43″N 74°8′45″W
    So build a shroud Shrouds + fans + heatsink it's gonna end up being like 18" long lol.
    Core
    Core i7 920
    eVGA X58 LE SLi
    2x3GB Mushkin DDR3-1600
    BFG 8800GT OC
    Seagate 7200.12 1TB + Maxtor 320GB
    LianLi A05B
    Cooling (all internal)
    2x BI GTS 360
    2x DDC3.2 + Ek top
    EK Supreme LT
  25. #75
    Aug 2007
    Orange County, Southern California
    When my TRUEcu arrives, I'll be mounting it vertically. To solve the weight problem, what do you guys think if I used clear fishing wire to tie the heatpipe endpoints to the roof of my case?
    EVGA X58 SLI Classified E759 Limited Edition
    Intel Core i7 Extreme 980X Gulftown six-core
    Thermalright TRUE Copper w/ 2x Noctua NF-P12s (push-pull)
    2x EVGA GeForce GTX 590 Classified [Quad-SLI]
    6GB Mushkin XP Series DDR3 1600MHz 7-8-7-20
    SilverStone Strider ST1500 1500W
    OCZ RevoDrive 3 240GB 1.0GB/s PCI-Express SSD
    Creative X-Fi Fatal1ty Professional / Logitech G51 5.1 Surround
    SilverStone Raven RV02
    Windows 7 Ultimate x64 RTM
