I have a 250GN SATA HDD with a AMD 5200+ on a MSI K9N SLI mobo. During the OS isntallation it randomly shuts down. how can I fix this?
[SIZE="1"]Gateway MT6707 Notebook
Intel Pentium Dual Core T2060 1.6 GHz
Memory 2048 MB 533MHz DDR2 SDRAM
Intel Graphics Media Accelerator 950
224 MB shared video memory
High definition audio 2 channel
160 GB HD
8X Multi-format dual layer optical drive
802.11g wireless LAN
4 USB 2.0 ports
If you have done a transaction with me, please fill out my heatware. http://www.heatware.com/eval.php?id=64039
If you believe in Jesus Christ and are 100% proud of it, then put this in your sig
Hi kylepaddock
Unfortunately i have bad news regarding your problem.99.9% chance it's the motherboard problem(the whole K9N suffers from it).You can find out more at:
http://www.google.com/search?q=MSI+K...ient=firefox-a
Here-> link is the MSI sticky forum thread regarding this issue(it's capacitor issue near the vrm section of the board,it should have higher capacitance rating than the implemented one so the board suffers from the shutdown problem randomly-mostly connected with IDE controller in some way)
Good luck with your problem,maybe it's some other issue than the one i described.
160 GB HD
4 USB 2.0 ports
Kyle have you managed to install any OS on your system?If you have,try burning CD or DVD or try playing 2(yes 2) DIvX/DVD films at the same time from your hard drive(it's important they are located on your HDD when you play them)
160 GB HD
4 USB 2.0 ports
Read the links from my first post i did in this thread.
